It is currently Wed Oct 28, 2026 11:07 pm
PostPosted: Wed Jun 27, 2012 2:40 am
We were a little concerned due to the reviewing options not being updated somehow to cope with the new background info in the ipiVideo file. Under the hood everything is working, but somehow the 'Show Background' and 'Pose Mismatch' do not show the actual background on which the analysis is performed.
To illustrate, the following image shows the pose mismatch view with the performer. Somehow the t-pose made it in the background. No abnormal mismatch values so everything is working well.
The following image shows the performer walk 'through' his t-pose, the reviewing of the mismatch does not add up, though the values again do not show disturbing results.
Conclusion: analysis working well, reviewing however is bugged.
PostPosted: Wed Jun 27, 2012 3:44 am
There was an issue with background processing in Studio releases prior to 2.0.0.133 (see release notes). May be you are talking about the same. Have you tested with this release?
I guess you do not evaluate background while actor is standing in T-pose ;)
And also, as Beta stage is finished, and your issue is not about Recorder, I suggest you to post a new topic if you continue to have this issue.
PostPosted: Wed Jun 27, 2012 4:49 am
Ah, my bad. mixed this thread up with ipiStudio.
However, we did use the 2.0.0.133 release. We also captured an empty(no actor) shot with the recorder.
PostPosted: Wed Jun 27, 2012 3:44 pm
Could not reproduce this issue with incorrect background.
Show background seems working quite OK. It does not work in Pose Mismatch mode and it does not really make sense - you'll only see totally black picture. Also it does not work for RGB picture in depth videos - because in depth video RGB is only supplementary. The same behavior was in 1.x version.
Can you provide us video file you experience issue with?
PostPosted: Mon Jul 02, 2012 3:30 am
I will send the videofile + scene + actor file to ipi[at]ipisoft.com. You should be recieving it soon.
PostPosted: Mon Jul 02, 2012 12:58 pm
We have downloaded your video. We will make some comments after having a look.
PostPosted: Tue Jul 03, 2012 8:05 am
Hi again
I've played a little with your video and have not got any of the issues you've mentioned.
Here are my screenshots for Show Background and Pose Mismatch.
File comment: Pose Mismatch in action
File comment: Show Background in action
PostPosted: Thu Jul 05, 2012 1:59 am
Well isn't that just awkward. I'll test on another pc as well to see if i can recreate the problem. I have to mention we're running the Basic Trial version.
Users browsing this forum: Google [Bot] and 33 guests
