It is currently Mon Nov 09, 2026 1:52 am
Post a new topicPost a reply Page 3 of 3   [ 25 posts ]
Go to page Previous  1, 2, 3
PostPosted: Tue Nov 23, 2010 8:42 pm
McWannabe wrote:
BTW - I got 'too many connections' error msg for quite a while earlier today. Some potential users might be getting this error msg too and get discouraged?
Thanks for info. This is a problem with load balancing for our forum. It will take some time to fix.
PostPosted: Tue Nov 23, 2010 9:26 pm
Michael Nikonov wrote:
GSpot is a highly respected application and is recommended by Microsoft: http://www.headbands.com/gspot/reviews/ ... index.html . You will not get any problems from GSpot. It is the only way to understand what happens with DirectShow codecs on your PC.
VLC absolutely cannot be the cause of the problem, because VLC is completely separate from DirectShow infrastructure. VLC has its own integrated codecs (non-DirectShow) and its own player.
The problem on your computer is most likely caused by some third-party DirectShow codec. The fastest way to find the problematic codec is to use GSpot to analyze the set of DirectShow codecs used by your PC for opening MJPEG videos.
Michael - I installed GSpot 2.70a and copied the file that crashed to the interface.
Gspot seems to think there is no problem, which makes sense as both VLC and Windows Media Player can both play it.
It says
Codec MJPG
'Codec(s) are installed.
File Length Correct
OpenDML (avi V2.0)
Video 50.5mb(99.95%)
AVI Overhead 24.4 KB (0.05%)
Len 0.12425
Frms 497
kbps 34139
Qf 0.695
Pics/s 40
Frames/s 40
pic 1280 x 960
sar 1.3333(4.3) par 1.000(1:1) dar 1.333(4.3)
How do I proceed? Only iPi software is having a problem reading the file?
PostPosted: Tue Nov 23, 2010 9:58 pm
What does it show at the bottom of the screen, in "Proposed Codec Solutions and Tests" section (you have to click "1" button to display the info on codecs)?
We need this info for debugging.
We will be able to respond in about 36 hours from now as we need to go to airport now to fly across the ocean.
PostPosted: Wed Nov 24, 2010 11:46 am
It looks like the Matrox codecs are the problem. I un-installed, and now I can play in iPi Studio.
However, as VLC and Microsoft seem to be able to play the video with the Matrox codecs installed, and Matrox is a rather large popular company for folks in the graphic world, it might be good to have iPi Studio find a way to choose the codecs it uses (as VLC and MS seem to be able to).
Thanks!
PostPosted: Sat Oct 13, 2012 12:52 pm
McWannabe wrote:
Please change the play button to pause when clicked.
Done at last! Check out version 2.1.1.140.
Users browsing this forum: No registered users and 71 guests
