hi again!
aaalright, so this time i used 6 cameras in a half-circle setup and did 5 ground-points, plus, the maglite is always visible to all the cameras (
0.057% misdetections. i used the old maglite since the new one turned out to be way too bright for calculation...the "dot" was almost as big as a light-bulp, and sometimes bigger than the tracking-square ;) ..just as info ).
i tried to go for the "cage" method (as seen in a tutorial by manymotion/greenlaw - thanks by the way - which is apparently also suggested by most users which are aktive here in the forum). i started the video with the plain background but set my ROI for the calculation from frame 424 to 3908 (since there, my marker is visible to all cameras).
my results after placing the groundpoints:
Distance cam01 to cam02: measured: 4m, computed: 3.96m (4cm off)
cam01: measured: 1.57m, computed: 1.57m (set the scene scale to match it)
cam02: measured: 2.41m, computed: 2.40m (1cm off)
cam03: measured: 1.74m, computed: 1.74m (baam!)
cam04: measured: 1.61m, computed: 1.64m (3cm off)
cam05: measured: 3.01m, computed: 3.04m (3cm off)
cam06: measured: 1.56m, computed: 1.61m (5cm off)
all in all i'm quite happy with the results (although 5cm off is quite a bit...), but i'm curious why it turned out to be quite accurate this time, since i actually didnt make anything different than the last times, but using more cameras.... any ideas?
thanks guys!
PS: heres an image of the result:
