It is currently Thu Oct 29, 2026 6:34 pm
PostPosted: Fri Mar 01, 2013 8:49 am
Hello all greetings from Brazil :)
None of the mocap are exporting Head - flexible spine or fingers to Iclone. Even if I use 3dxchange 5.
Can any one help me on that?
A wish:
I wish IPI studio would have key frames to anchor or set free the foot - The conditions to not have yellow around the foot are quite a variable of place and time
for me. Any comments ?
Thanks a lot
Natofor (Toby)
PostPosted: Fri Mar 01, 2013 8:57 am
Yes. In Motion Builder, you would select the bone and create and effector at that location. Then you can envelope a rotation and/or positional constraint. It would be great if iPi Mocap Studio had a similar feature.
In the meantime, here's what I do: depending on the action, apply different Jitter Removal Settings for the legs. For example, in the frame range where the character is standing still, I use a very high JR setting for both legs--but when the character is stepping, walking, jumping or running, I use a much lower JR setting for the moving leg(s). Remember to 'touch' Trajectory Filtering after you've run multiple Jitter Removal passes--this helps smooth the transition between different settings.
PostPosted: Fri Mar 01, 2013 4:11 pm
Thanks a lot, as always you are of great help. :)
Toby (natofor)
Users browsing this forum: No registered users and 85 guests
