It is currently Sat Aug 15, 2026 11:11 am
PostPosted: Sun Aug 11, 2013 1:37 pm
Hi there
I've finished filming yesterday with iPi Recorder 2 and now I've downloaded trial version of iPi Mocap 2.4 to test the captured material, but when i try to license the software clicking in "free trial license", i get this error:
Quote:
iPi Mocap Studio version 2.4.0.154 []
.NET: 2.0.50727.6407
OS: Microsoft Windows NT 6.2.9200.0
System.ArgumentException: Culture ID 8192 (0x2000) is not a supported culture.
Parameter name: culture
at System.Globalization.CultureTableRecord.GetCultureTableRecord(Int32 cultureId, Boolean useUserOverride)
at System.Globalization.CultureInfo..ctor(Int32 culture, Boolean useUserOverride)
at System.Windows.Input.InputLanguageSource.get_CurrentInputLanguage()
at System.Windows.Input.InputLanguageManager.get_CurrentInputLanguage()
at System.Windows.Documents.TextSelection.EnsureCaret(Boolean isBlinkEnabled, CaretScrollMethod scrollMethod)
at System.Windows.Documents.TextSelection.System.Windows.Documents.ITextSelection.UpdateCaretAndHighlight()
at System.Windows.Documents.TextEditor.OnGotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e)
at System.Windows.Controls.Primitives.TextBoxBase.OnGotKeyboardFocus(KeyboardFocusChangedEventArgs e)
at System.Windows.UIElement.OnGotKeyboardFocusThunk(Object sender, KeyboardFocusChangedEventArgs e)
at System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp)
at System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
at System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew)
at System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
at System.Windows.UIElement.Focus()
at System.Windows.FrameworkElement.OnPreviewGotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e)
at System.Windows.Interop.HwndKeyboardInputProvider.FilterMessage(IntPtr hwnd, Int32 message, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
I'm using a Toshiba Satellite S855-S5378 Laptop if that can help.
Thanks for the help.
-R.C
PostPosted: Mon Aug 12, 2013 2:46 am
What is your OS locale setting (region, language etc.)?
Try to reinstall .NET Framework 3.5, this may resolve the issue.
PostPosted: Mon Aug 12, 2013 10:12 pm
Region is center america, and language is english/spanish.
It came with .net 4.0 preinstalled, i just re installed and the licencing problem was solved, but it keeps throwing errors with .net framework on calibrating, and sometimes just crashing for no reason.
PostPosted: Tue Aug 13, 2013 1:38 am
iPi Mocap Studio runs on .NET 3.5, not 4.0. .NET 3.5 is not installed automatically with Windows 8, however, it should be automatically downloaded and installed "on demand", when launching .NET 3.5 app like iPi Mocap Studio.
Have you reinstalled .NET Framework 3.5 or 4.0, or iPi Mocap Studio itself?
Does it throw the same or other errors on calibration?
Is there any diagnostic info related to the crashes?
Users browsing this forum: No registered users and 71 guests
