It is currently Tue Nov 10, 2026 12:55 am
Post a new topicPost a reply Page 2 of 2   [ 19 posts ]
Go to page Previous  1, 2
PostPosted: Fri Jan 10, 2014 6:30 pm
Here's the latest:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at #=qqYupkjEjyOSRBpcoM8M$rBZ9VMdJnKt79LDoFM7NzHDlZuL6geTFdNs8vy6O9H$j.#=q2bRLRFmygOcpcEgaJbnB7Q==()
at -.dje_q8JSA8WULFJJRE3FHJN87VXKVQ8LZRUDWY7TPJ7NHS9RELRJEVZ44G4XT83NQ6JNV9XJFTD5GTHFD3_ejd.OnPaint(PaintEventArgs #=qez_RXkXhmk4k9HSHcCw3Yg==)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
iPiMocapStudio
Assembly Version: 2.5.1.159
Win32 Version: 2.5.1.159
CodeBase: file:///C:/Users/Bibby/AppData/Local/Apps/2.0/R239MJTA.16P/90L563JZ.OJN/ipim..tion_45b20dbe8f508542_0002.0005_5c5332f10eb6b53b/iPiMocapStudio.exe
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5453 built by: Win7SP1GDR
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Deployment
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
zx_d2c9cb824d834f6ab57aa19f9e784be0
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.Xna.Framework
Win32 Version: 3.0.11010.0
CodeBase: file:///C:/Windows/assembly/GAC_32/Microsoft.Xna.Framework/3.0.0.0__6d5c3888ef60e27d/Microsoft.Xna.Framework.dll
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationTypes/3.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsFormsIntegration/3.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
msvcm80
Assembly Version: 8.0.50727.4940
Win32 Version: 8.00.50727.4940
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_none_d08cc06a442b34fc/msvcm80.dll
iPiHelpers
Assembly Version: 1.0.0.4
Win32 Version: 1.0.0.4
CodeBase: file:///C:/Users/Bibby/AppData/Local/Apps/2.0/R239MJTA.16P/90L563JZ.OJN/ipim..tion_45b20dbe8f508542_0002.0005_5c5332f10eb6b53b/iPiHelpers.DLL
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
PostPosted: Sat Jan 11, 2014 12:14 am
Thanks. I suppose you've got the text under the "Details" button, and it's the same as in the first post.
But in the screenshot there is also the "Error" window shown by Mocap Studio, and it contains different text. Please try to get it as well. It should be automatically copied to the clipboard. So, when you see the error, just press Ctrl+V to paste it somewhere.
PostPosted: Sat Jan 11, 2014 1:48 am
Here ya go:
iPi Mocap Studio version 2.5.1.159 [<unknown>]
.NET: 2.0.50727.5472
OS: Microsoft Windows NT 6.1.7601 Service Pack 1
at #=qrnwKR8RKyb2a8pGrySjDIn0PbKpXmfGvyVbQCgO1bS0=.#=q0J$Lft6Qdy7J$MrfO3dKjk9yC20Fvpk2bxmbl13Tn2U=()
at #=qrnwKR8RKyb2a8pGrySjDIn0PbKpXmfGvyVbQCgO1bS0=.#=qpVmBXn$kcnUKTUrh4M03JA==(IServiceProvider #=q4OAhiNnOmJlgaPzb8_K0xg==) at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=q3B6oVi6a79U7DPnkXDz85xdZGlosA5degjL2iUw7bhA=(MethodBase #=qsOY3J6M8IqsaHUInAd0Tjg==, Boolean #=qUgoB7FxxC2HXsmNXwsRnQA==)
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qv_ZbRFhuEWGK7LMktvW8mSdFD4hU8X$Z9GstnuN1kZU=(#=qO1Y4DplFwBnH_OoID8wasmr1sEsNT27H$9Ewc_ug96E= #=qsOY3J6M8IqsaHUInAd0Tjg==)
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qRl6quY8lffRCe7rzIkJp4yzhEfhywTCoQBWegfR_tN4=()
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qOpYMytLqegFE58NNuvgKZ_eXymNMF7_HWb2QeF0alMU=() at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qT4Xtvbw6LciuNKOfGTl$KPH3F$QWeDvJPtCoWKuty0w=(Object #=qFA7zbHjOs0CH7GboH9BbUQ==)
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qg6yXi2PvcHxjugjdHK2783GtB7DRDio_$R$DuIOgcFU=()
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qFA$AgCtL2belon8V6NHz5Q==(Object #=qZqHXv484EcDy5oHj0mkEYQ==, UInt32 #=qgiYI2l_RinAvPM1LRnO05w==)
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qaySKtD$pwDtB$WMsqp$a2w==()
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qtippMs1HVkNnfihZI7Js8LcfgywWYqzf1Buit57zWDY=() at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qT4Xtvbw6LciuNKOfGTl$KPH3F$QWeDvJPtCoWKuty0w=(Object #=qFA7zbHjOs0CH7GboH9BbUQ==)
at #=q3ip5TXzDZ$OrLY1hClTsHK1J7HXlLsm0vT9PZ_U2ExQ=.#=qv40BOabEO1PsYShMPHU37Q==(Stream #=qp7ndKevjRhbQmohLZWW17Q==, String #=q6DufoEwDEMhYn$BooBvVDQ==, Object[] #=qLuKs_L8TwFMcG1wk6tQGSQ==, Type[] #=qGApRtjqMenEjUmFTY7Ng4A==, Type[] #=qaG8MWTyQUF7d9ctznH3dHQ==)
at #=qqYupkjEjyOSRBpcoM8M$rBZ9VMdJnKt79LDoFM7NzHDlZuL6geTFdNs8vy6O9H$j.#=qV6Pb5WWVkG5wEMtkJHl9VA==(IServiceProvider[] #=qOcMh5aiuLZm2JvK0DRg8TSDgClW3QXdiVzqwmaHuf50=)
at -.dje_q8JSA8WULFJJRE3FHJN87VXKVQ8LZRUDWY7TPJ7NHS9RELRJEVZ44G4XT83NQ6JNV9XJFTD5GTHFD3_ejd.#=q8R_0SC_MNV$1ViHvWvwShfGW$HYkRev2vftv2Bmq$5Y=()
at -.dje_qJAM6G7P7EG8SCRTTES474QNZ74EKNT2RFCAF47GUM5STE596LRDQ_ejd.#=q0QrFjLatfRnwfbNbJk1751BWjonbFqzACnWYc$bapB4=(Object #=qPpqkan$iyFH7fpsouQtW9w==, RoutedEventArgs #=qh_8fKcgWMyeNWtCZn7i1Bw==)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.Resize(ICompositionTarget resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
PostPosted: Sun Jan 12, 2014 6:08 am
Thanks, this helps a lot to figure out what's going on.
PostPosted: Mon Jan 13, 2014 5:53 am
Please run a test app (attached) on Mac Mini, and post its output.
File comment: Test app
NVidiaGF320M-Test.zip [11.69 KiB]
Downloaded 782 times
PostPosted: Wed Jan 15, 2014 10:23 pm
Here is the output:
Graphics adapter: RDPDD Chained DD
Test Depth24Stencil8: True
Failed to initialize GraphicsDeviceSystem.InvalidOperationException: An unexpected error has occurred.
at Microsoft.Xna.Framework.Graphics.GraphicsDevice..ctor(GraphicsAdapter adapter, DeviceType deviceType, IntPtr renderWindowHandle, PresentationParameters presentationParameters)
at NVidiaGF320M_Test.XnaFormsControl.CreateXNAGraphicsDevice()
at NVidiaGF320M_Test.XnaFormsControl.InitXnaGraphics()
at NVidiaGF320M_Test.MainForm.OnLoad(EventArgs e)
PostPosted: Thu Jan 16, 2014 12:10 am
Did you run from the program using Remote Desktop or in virtual environment from Mac OS? The adapter name "RDPDD Chained DD" instead of expected "NVIDIA GT 620M" makes me think of this.
Please run from Mac Mini itself, booting into the Windows partition, as you normally run iPi Mocap Studio.
PostPosted: Thu Jan 16, 2014 12:56 am
Doh, your'e right. I also forgot to try to launch the app after installing the latest nVidia drivers from the Mac Mini instead of RDP. It works now :)
Mac Mini Mid 2010, Windows 7 64-bit, latest nVidia drivers can now run both the Recorder and Studio apps.
Thanks!
PostPosted: Thu Jan 16, 2014 2:26 am
OK, cool :)
Users browsing this forum: No registered users and 23 guests
