It is currently Mon Nov 09, 2026 3:11 am
Post a new topicPost a reply Page 3 of 4   [ 31 posts ]
Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: After Calibration
PostPosted: Tue Apr 28, 2015 3:47 pm
It started working again after the update. Thanks. One more problem. I tried pairing my ps move controller with motioninjoy but in the Adapter section it says "Waiting for bluetooth adapter to be connected." I have already installed all drivers as the tutorial suggested. Is there any possible solution?
PostPosted: Wed Apr 29, 2015 4:12 am
You mean that DS3 tool does not "see" your BT adapter? It may simply be not compatible with MiJ.
What is your BT adapter model?
PostPosted: Wed Apr 29, 2015 6:47 am
I'm using Apple Broadcom (firmware version v99 c8866.)
PostPosted: Wed Apr 29, 2015 12:18 pm
Does it support BT 4.0? If yes, then most probably it won't work with MiJ and PS Move.
You should get an adapter capable of BT 2.1 with EDR (and not 3.0 or 4.0), such as
http://www.newegg.com/Product/Product.aspx?Item=9SIA24G1721651
PostPosted: Sat May 02, 2015 11:08 am
Hi VMASLOV, i read in this post :
viewtopic.php?f=5&t=9232&p=18724&hilit=Move+controllers#p18724
that the bluettoth adapter that works is the trendnet tbw-106UB, he actually pair 9 psmoves, but you are recommending the trendent tbw-107UB, so which one of these 2 is the one that works? and if the 2 of those works , which one is the best?,im using ipi record 2 latest version by the way. Thanks in advance
PostPosted: Sat May 02, 2015 11:18 am
Both mentioned TRENDnet adapters work, but only the older revisions, which support Bluetooth 2.1 with EDR. Newer revisions of the same models support Bluetooth 4.0 and most probably do not work with PS Move and our software, though we have not tested them yet.
106 model is Class 1 (up to 100m range), 107 model is Class 2 (up to 10m range). So you may prefer 106 for better range, but it seems harder to find the older revision of this particular model in stores.
PostPosted: Sat May 02, 2015 1:10 pm
Hi vmaslov, thanks for your quick reply. one last question, what do you mean by revision? drivers/firmware? and what would be the version number of the old revision to try find it on the net. thanks again
PostPosted: Sat May 02, 2015 1:16 pm
It's the revision of hardware itself. It's a shame TRENDnet have not changed the model names when releasing new hardware, but now we have that confusion. These are the pages of older adapters on manufacturer's website:
http://www.trendnet.com/products/proddetail.asp?prod=170_TBW-106UB
http://www.trendnet.com/products/proddetail.asp?prod=175_TBW-107UB
They can be distinguished in the stores by NOT supporting Bluetooth 4.0.
PostPosted: Sat May 02, 2015 1:22 pm
fortunately an store here in my country sells both models version 1.0r:
http://articulo.mercadolibre.com.pe/MPE ... rendne-_JM
http://articulo.mercadolibre.com.pe/MPE ... sion-1-_JM
that´s the revision 1 ,right? Now, i dont know if this is true. Does the version 1.0r should be typed in the package?. thanks for the info and your help
PostPosted: Sat May 02, 2015 1:30 pm
Yes, the title and specs state that these are older devices.
I do not think there is special note of the revision on the package. Because at the time of manufacturing it might not be known there would be any other revision in the future. However, there should be NO any mention of Bluetooth 4.0 on the package.
Users browsing this forum: Google [Bot] and 120 guests
