It is currently Mon Nov 09, 2026 6:52 pm
PostPosted: Fri Nov 29, 2019 12:03 pm
Hello everybody
i just paid 2 AZURE KINECTS DK that I intend to use with IPISOFT BASIC. For the moment I use the TRIAL version of 30 Days and I would like after, to get the unlimited version.
But I have some problem for using the 2 AZURE KINECTS together. The wires (USB2 for the socket + USB3 for the connection) supplied with the AZURE KINECTS are very short, if you want to use them on the same PC.
And by combining them with extensions (repeater USB cable) the flow is no longer enough to work with. Maybe I use those who are not good?
For those who uses the system already, do you use a single PC for multiple AZURE KINECTS? Or one PC per AZURE KINECTS DK ? If so, can you give me a tutorial step by step on how to do this? If not, how could you place the 2 AZURE KINECTS at a good distance from each other, with the same PC ?
Thank you in advance.
PostPosted: Thu Dec 26, 2019 12:57 pm
I use 2 of:
https://smile.amazon.com/gp/product/B06XCDN92Y
And I have no issues. Though the cables got bad reviews.
I use one computer with a very fast GPU. Calibration is the difficult part. Use this:
http://docs.ipisoft.com/Dual_Azure_Kinect_Samples
I personally used a mag light. It was just a very powerful LED flashlight I already owned. It worked much better than trying to calibrate with the board. I also have 2 (very, very cheap) tripods. The power cables are also very short and you will need extensions or plugs for each.
PostPosted: Fri Dec 27, 2019 8:50 am
Thank you so much!
