It is currently Mon Nov 09, 2026 3:42 pm
PostPosted: Sat Jun 06, 2020 10:51 am
Hello, sorry for all the questions
1) What is the best way to hold a sword and make sure IPI knows all its rotations + have IPI not get confused by the object itself? (can it knows I have a sword in my hand?)
2) About keyframes, what is the best way to take advantage of them? when I reposition the hand and press "refit" it takes my error hand to the right place, why do I need to add a Keyframe?
3) about the background, I got black thin cloths that stick to my shape. is it a good idea to throw whtie sheet on my stuff to make the room as white as possible?
4) I have rtx2070. can I speed things up by adding another one? or it's better to switch it with 2080ti?
thank you ! :)
PostPosted: Sun Jun 07, 2020 9:18 pm
Some suggestions:
If you have a motion controller, attach the controller to the hilt of your prop sword. This will record the rotation of the sword. Apply this motion to the character's hand that's holding the sword and then parent the sword to the hand. This should work assuming the character is keeping a firm grip on the sword.
If you're not using a prop sword, just hold the motion controller as the sword. You'll have to pantomime it for realize, that is, pretend it has greater weight and length than the controller.
I did a series of sword test years ago before motion controllers were an option. For those tests, I used a Nerf sword which is thin enough not to interfere with PS3 Eye capture, and is the right size to help with the performance. Of course, I had to pretend the weight. Since this was before motion controllers, I just parented the sword to the hand in the animation program and animated the wrist rotations manually. This is a little more work but it's really not that difficult.
(That sad, even with rotation capture devices, you'll probably need to make some adjustments anyway.)
For keyframing the hand and sword rotations, you can do this in iPi Mocap Studio but I think you'll find this easier to do in your animation program after the main re-targeting/correction part is done and exported from iPi. The reason being that your animation program may offer more options for rigging the sword to make it easier to animate.
(FYI, later on, I used the same Nerf sword as a stand-in prop for a guitar during a multi-Kinect capture and that worked out well too. In this situation, rotation was not captured. The prop was mainly for keeping my hands 'correctly' positioned. The guitar was then setup in my animation program to target the hand positions, so it was done kind of 'backwards'.)
PostPosted: Mon Jun 08, 2020 2:09 am
Keyframes in Mocap Studio only contain finger rotations (no wrist rotation or position) - the part of skeleton which cannot be tracked neither with cameras nor with motion controllers. You may not use them at all preferring to handle fingers in your animation software. However, they can be useful to as a quick start for hand poses in the final animation because in Mocap Studio you have a video reference before your eyes.
It is good for a background to be distinct in colors from an actor. But there is no necessity in uniform color. If you use black for an actor then ensure you don't have black in the background.
Even more helpful may be adding colors to an actor clothing. Say, adding a T-shirt of a lighter color on top to help the program to distinct between arms and trunk.
According to benchmarks RTX 2080ti is ~30% faster than RTX 2070 while being 2 times more expensive. Dual RTX 2070 is expected to track ~60% faster than a single one. So yes, it makes sense to use dual RTX2070 if you've got a Pro license which allows multiple GPUs. And I assume you do as you shoot with 8 cameras.
Please be aware that the above numbers are speculative as apparently we do not test our software with all possible GPU setups.
PostPosted: Mon Jun 08, 2020 5:48 am
Btw IPI soft team if you want to get in touch for collaborations feel free to mail me ravidamitb@gmail.com
this is the RPG game i am making and using IPI for it now
https://www.instagram.com/the_cloud_tower/
Greenlaw wrote:
Some suggestions:
Thank you! I ordered two pack of ver 2 ps move.
I'll try to attach one of them to the hilt while still manage to hold it (fake metallic katana)
thank you !
you can see my test here (before asking this questions)
https://www.facebook.com/vaylor.strongm ... 502649588/
PostPosted: Mon Jun 08, 2020 6:34 am
Glad to help! Sorry my writing was a little disjointed in that post. I was really tired when I wrote it but I hope most of it made sense. :P
PostPosted: Mon Jun 08, 2020 7:01 am
It did
I am thinking if to getting 3 ps moves, 1 for the sword and 1 for each hand
what do you think?
PostPosted: Mon Jun 08, 2020 7:12 am
TBH, I never tried that. I wonder if you'll encounter any issues with motion controller devices being too close to each other? Just a thought.
Personally, I think keeping it simple might be better. The motion controllers capture credible motions for the wrists and head but the accuracy isn't always perfect. (for example, they can drift a little.) Having two controllers in that hierarchy might possibly make it 'wobbly'? That's just a guess...I really don't know.
When you get your gear, you should definitely experiment further...my own tests were very basic, mostly 'proof-of-concept' in case I ever needed to record something like that later. Please post any discoveries you make...I'm very curious to see what happens.
If anything, the third motion controller can be used for head rotation capture. For me, this is probably more important.
Good luck!
P.S., I'll try some sword tests here when I'm able to and let you know how it goes. Unfortunately, ATM, I'm having to re-build my system drive from scratch which is probably going to take a couple of weeks. Sigh!
PostPosted: Sun Jun 14, 2020 4:08 am
Good luck!
was organizing my apartment for using this for long time. will update results soon
PostPosted: Sun Jun 14, 2020 11:39 am
Cool! Looking forward to your posts.
Sigh! I've been busy working on rebooting my website so not much mocap activity here yet. I'm going to finish this today though....and then I can move onto the more fun project of using iPi Mocap Studio. :)
Users browsing this forum: No registered users and 32 guests
