It is currently Sun Nov 08, 2026 1:26 pm
PostPosted: Sat Aug 03, 2024 3:35 pm
In the documentation, GoPro and SJCAM are recommended for use in an action camera based setup.
I like that they benefit from a higher FPS and FOV, and I've seen online that you can use action cameras as webcams, for example: the SJ4000 by SJCAM is advertised as having a webcam functionality.
https://www.sjcam.com/cameras/action-cameras/sj4000-dual-screen/#:~:text=with%20a%20case-,Webcam,-4K%20/%2030FPS
Therefore, I'm wondering if anyone has tried it specifically for iPi mocap, since you theoretically get the best of both worlds based on the comparison outlined in the documentation.
https://docs.ipisoft.com/Cameras_and_Accessories#:~:text=Motion%20Capture.-,Web%20Cameras%20vs.%20Action%20Cameras,-The%20overall%20workflow
PostPosted: Sun Jun 08, 2025 11:46 pm
https://www.sjcam.com/cameras/action-cameras/sj4000-dual-screen/#:~:text=with%20a%20case-,Webcam,-4K%20/%2030FPSslope game
I’ve tried the older SJ4000 with iPi in webcam mode — it works, but has drawbacks: limited control over settings, inconsistent frame rate, and potential sync issues. For better results, consider recording to SD and syncing manually. Curious if the newer Dual Screen model improves on this!
Users browsing this forum: No registered users and 41 guests
