My PC env specMB: GIGABYTE B760itx AORUS PRO DDR4
CPU
13th Gen Intel(R) Core(TM) i5-13490F
Memory
32.0 GB
Available 27.8 GB
Cached 1.7 GB
GPU 0
NVIDIA GeForce RTX 4070 Ti SUPER
Driver version: 32.0.15.6590
Driver date: 9/26/2024
DirectX version: 12 (FL 12.1)
iPi Recorder 4.7.0.98
OS: Microsoft Windows NT 10.0.19045.0 (64 bits)
.NET: 4.7.2.533325
CPU count: 16
GC: workstation (Interactive)
Running in 64 bits
ISSUE that I metThe way to produce the issue:
1. Open 'Recorder 4'.
2. Plug in just '1' C922PRO cam.
3. Start recording, and see
Preview + Cam Setup.
3.1. I can see Cam but no Microphone even click on refresh.
3.2. The preview.
4. Then follow the proc and the recorded video is 59.6fps, which is nothing wrong (juts like IPI doc said, 'it has a little bit drop from 60fps').
5.
Then do another record. The cam is plugged in still, no re-plug. 5.1.
Now Microphone shows up. But the preview has only 60fps for few seconds then drop to <20fps. Attachment:
5.2.
Left the cam setup with no change and the color is different from the 1st shoot. Attachment:
Other ConcernsI found setup like 'Auto Exposure' or 'Auto White Balance' can impact FPS.
I can tune setup params, and got a stable 1080p30fps. When I use the same setup and switch to 720p60fps, it only gives me ~32fps.
I have no idea why this happened
even I only use one camera. 1080p should be = 1.5^2 * 720p pixels and 60fps = 2 * 30fps, which will have similar data size.
I will record the issue reproduction into one video and post later.
