It is currently Sun Nov 08, 2026 7:22 pm
PostPosted: Wed Dec 22, 2010 5:20 pm
Hello Ipi's developers! I got the following problem, ever since v1.0.0.109, i keep getting major leg jitters. I tried everything to get rid of them, re-calibrating, darker/lighter actor colours, changing actor height/morphs, ground tuning and light amount/position.
Before 109 i didn't have this problem, i had a perfect track, though 109 gives much better jitter removal. so what i want to do is track using 107/108 and jitter removal on 109, can you please link me to 107 and 108, thank you so much!
P.S. btw, i am kind of sure 109 new configuration did mess up the leg tracking, can any developer support me on that? i mean i tried everything!
PostPosted: Wed Dec 22, 2010 8:55 pm
Okay! found 108 from the unlimited amount of files i have, tested it and no leg jitter, same file, same configuration, this is a hint for anybody that faced the leg jitter problem, cheerios to all and marry Christmas!
PostPosted: Thu Dec 23, 2010 3:34 pm
Thank you. We appreciate your feedback. We will look closely at this problem. Greenlaw and other users also reported this problem. It will take us some time to debug but we will try to fix this problem in next release.
PostPosted: Thu Dec 23, 2010 4:43 pm
Thanks for tracking this down. I was beginning to think I imagined less feet jittering in past builds. :)
I'll see if I can find 108 around here and do a test myself to confirm.
PostPosted: Wed Dec 29, 2010 10:16 am
Do you see unusual jitter in latest version before or after Jitter Removal?
Can you please send me example BVH files with leg jitter from latest version? Just a simple motion like T-pose or standing still will be enough.
PostPosted: Thu Dec 30, 2010 9:00 am
The unusual jitter happens before the removal. Tracking results of 108 uncleaned nearly matched 109 cleaned, here is a public hot link activated folder for you, contains a 108 and a 109 sample.
http://hotfile.com/list/1213984/8861c9d
P.S. sometimes the jitter removal tool caused jitter and made it worst, dunno why.
