It is currently Sat Aug 15, 2026 4:05 pm
Post a new topicPost a reply Page 4 of 5   [ 43 posts ]
PostPosted: Wed Oct 12, 2011 11:21 pm
Greenlaw, thank you very much for your detailed answer. You are absolutely correct as usual!
PostPosted: Thu Oct 13, 2011 2:46 am
Hi Andrew,
I tried that and got the same result.
Any other ideas?
andrew wrote:
mrbones wrote:
Yes I get a messy phycadelic picture.
Then when I load the new depth movie in iPi It shows 4 screens with an overlayed one picture.
with no depth data...
You can try to update the drivers for Kinect:
http://www.ipisoft.com/en/wiki/index.php?title=Quick_Start_Guide_with_Dual_Kinects#Drivers_Update
Also use the latest version of iPi Studio to open video from the new iPi Recorder. It looks like that you used the previous version to open your video.
PostPosted: Thu Oct 13, 2011 3:13 am
Any other ideas?
Could you please send us short sample video and screenshot of iPi Recoreder during recording?
PostPosted: Thu Oct 13, 2011 10:03 am
andrew wrote:
Any other ideas?
I have supplied the movie here at... http://www.truebones.com/iPiError.rar
Thanks and Cheers
PostPosted: Thu Oct 13, 2011 11:55 am
Yes. We see problems with depth data in this video.
MrBones, could you please try to turn off RGB recording:
  • in the "Camera Selector" dialog expand "Advanced Settings" box and check "Don't record RGB from Depth Sensors" option
Does it help?
PostPosted: Thu Oct 13, 2011 12:23 pm
I have a couple of questions about that panel:
Will disabling [Don't Record RGB...] speed up the data flow and reduce dropped frames? Is there any advantage to leaving it enabled?
PostPosted: Thu Oct 13, 2011 12:40 pm
Yes. It's narrow required USB bandwidth.
But will not affect on the disk usage.
Current version of iPi Studio doesn't use RGB information for tracking. It uses RGB only for visualization needs as an additional reference for result animation. Thus it almost your decision to use it or not. May be we had to disable RGB streaming by default... Hope we'll able to overcome current problems with it.
PostPosted: Thu Oct 13, 2011 1:04 pm
Yes, It seems that helped.
Now I can record depth Movies with one kinect using the new recorder.
Thanks and Cheers
Does it help?
PostPosted: Thu Oct 13, 2011 1:53 pm
@Andrew
Thanks for the instant response to my questions!
I'm setting up the the dual Kinect Sensors now. Hope my old laptop will support both. :)
PostPosted: Thu Oct 13, 2011 2:25 pm
Greenlaw wrote:
@Andrew
Greenlaw,
When you are finished with your work, is it possible for you to upload a video for the dual kinect
Would really appreciate it if somebody would show their work with the dual kinects.
Users browsing this forum: No registered users and 22 guests
