It is currently Sun Oct 25, 2026 10:55 pm
Post a new topicPost a reply Page 2 of 2   [ 14 posts ]
Go to page Previous  1, 2
PostPosted: Thu Oct 20, 2011 8:57 am
in evolver there are multiple rigs you can use... I chose one and they I had to manually in ipisoft assigned the motions to the idividual bones.. I guess ipisoft never does this automatically ? .. im still confused how I load everything into 3ds max... I know I can load a .bvh... and I can load a evolver skinned chahacter... I guess the key is knowing how to retarget the bones and motion to the ones in the evolver model.. right?
PostPosted: Thu Oct 20, 2011 12:51 pm
Yes I have seen many instances of using motions in a video game.
Check out DR Nano X and Melinas Conquest. Both for Iphone.
When I use Evolver riggs they come in without having to make a xml profile.
I usually check medium poly standard rigg and enable both DAE and FBX as export options.
In Max you would simply export as a Max file and hopefully your biped riggg hass the names to match.. if not use a MNM marker file in Biped.
PostPosted: Fri Oct 21, 2011 7:11 am
does motion builder do something in the whole process that cant be done with 3dsmax/bones or 3dsmax/CAT ?
PostPosted: Fri Oct 21, 2011 9:15 am
I don't use Max so I don't really know. What I do know is that Motion Builder is a standard for editing and applying motion capture in video games and in feature films, and and it appears that some of the MB tech is being ported over to Maya.
I think CAT for Max shares similar functions but I believe it's a separate development project. That's just a guess as I have no experience with it and little awareness of it.
Users browsing this forum: No registered users and 56 guests
