It is currently Tue Oct 27, 2026 7:18 pm
PostPosted: Wed Jun 22, 2011 6:54 am
Hallo,
I usually use a biomechanical manikin to analyze the type of movement. The manikin has angular limits with a maximum value (e.g. 70deg) and a minimu value (e.g. -65deg).
Some yours bvh files have output angles that change from -178deg to +180deg between two frame. This is only a change of 2 degrees but my manikin considers this like a change of direction. Could you suggest me the most suitable type of bvh files to export??
Rosemma
PostPosted: Wed Jun 22, 2011 1:43 pm
Are you using the "File->Export Animation" menu item to export animation? It exports animation in iPi format optimized for internal tracking tasks, and coordinate systems for joints may look random.
Try the "File->Export Animation for Motion Builder" menu item. It should produce more suitable data.
Can you send me an example of a skeleton used in your biomedical analysis? What software do you use for analysis (if it is not a secret)?
PostPosted: Sun Jun 26, 2011 11:43 pm
thanks Michael, the manikin we use is Jack (the commercial software) Do you know it?
