It is currently Tue Oct 27, 2026 1:43 pm
PostPosted: Wed Nov 21, 2012 3:35 am
[url]Hi guys,
in last iPi Mocap Studio update (ver. 2.1.2.141) has been added support for Valve DMX format export/import for use with Source Film Maker.
Has anyone here tried this or better worked it out with importing to Scout model?
I successfully captured motion sequence, imported target character of Scout model but I got stuck on importing .dmx animation to Scout in Source Filmmaker.
Does anyone have any idea how to figure it out?
Any help, thoughts or tutorial appreciated.
File comment: Screen of my project.
PostPosted: Fri Nov 23, 2012 6:21 am
http://wiki.ipisoft.com/Animation_expor ... er_and_DMX
PostPosted: Fri Nov 23, 2012 7:01 am
Thanks a lot,
this seems to be useful, but there is still problem with final step - importing .dmx animation from iPi Studio to Filmmaker.
Maybe I`m doing something wrong, but when I importing the .dmx file nothing happens and character doesn`t moving. Also there are no errors about missing channels and so on. Where could be the problem?
Thanks for any help.
PostPosted: Fri Nov 23, 2012 7:38 am
How do you import DMX into SFM?
(Attached is an screenshot of how it can be done.)
PostPosted: Fri Nov 23, 2012 7:44 am
Also, Jimer Lins's tutorial can be useful:
http://www.youtube.com/playlist?list=PLD4409518E1F04270
(although he used a more complex workflow via Maya - that was before we implemented DMX export)
PostPosted: Fri Nov 23, 2012 7:52 am
1: I`m importing DMX exactly the same way like you at your screenshot. It seems like, there is probably some bug in iPi Studio .dmx exporter or i don`t know what.
2: Jimer Lins`s workflow is maybe more complex, but useless assuming that iPiSoft DMX exporter would be working properly. In my opinion. Because you just skip the iPi Studio -> Maya –> MotionBuilder -> SFM steps with only one step of iPiSoft -> Source Filmmaker.
PostPosted: Fri Nov 23, 2012 8:06 am
Can you export from iPi Mocap Studio and upload here to this thread a test animation (in DMX) for Scout character, that has this problem?
PostPosted: Fri Nov 23, 2012 8:18 am
Actualy i got problem with HL2 human models (exactly group01/male_07) but the same issue is with Scout or any other models.
Anyway, i`m uploading you that test animation DMX for Scout. If you have time to check it i would appreciate it.
I can also upload animation of HL2 male model. Just let me know.
File comment: COMPRESSED SCOUT ANIMATION DMX.
scout_box.dmx.zip [122.43 KiB]
Downloaded 1635 times
PostPosted: Fri Nov 23, 2012 8:57 am
Hello Michael!
This is bug in version 2.1.2.142 of iPi Mocap Studio: during saving DMX file current user locale settings are used rather than invariant ones.
Workaround: in windows locale setting select dot (.) as a decimal symbol rather than coma (,).
Also we are going to publish update for iPi Mocap Studio in a few hours.
PostPosted: Fri Nov 23, 2012 9:02 am
OK, I see the problem. Floating point numbers in your file have decimal coma (European style) instead of decimal point (English style). Source Filmmaker actually does complain about this - you should be able to see error messages in "Console" tab.
A very quick workaround is to switch your Windows system to US/English locale and re-export the animation.
Or you can wait for us to release an update to iPi Mocap Studio (we will release it later today).
