PostPosted: Tue Jan 19, 2021 5:12 pm
While tracking forward to produce a new animation, my iPi Mocap Studio [PRO] has been crashing.
I have a NVIDIA graphics card on my PC and have already adjusted the settings according to the NVIDIA section of the following documentation on iPi Docs: http://docs.ipisoft.com/Maximizing_GPU_ ... cap_Studio
Please suggest any solutions you can come up with. It would be very much appreciated. Thank you.
I am going to go ahead and copy the entire error message below:
iPi Mocap Studio version 4.3.1.240 [PRO]
ENVIRONMENT
OS: Microsoft Windows NT 10.0.18363.0 (64 bits)
.NET: 4.7.2.528040
CPU count: 20
GPU Information:
NVIDIA Quadro RTX 5000 (VendorID=10DEh, DeviceID=1EB0h, SubsystemID=129F1028h, Revision=A1h)
Memory: 16 GB dedicated video + 0 B dedicated system + 32 GB shared system
Outputs: (1920x1080@60 R8G8B8A8_UNorm)
Intel(R) UHD Graphics 630 (VendorID=8086h, DeviceID=9BC5h, SubsystemID=98D1028h, Revision=5h)
Primary: no, Integrated: yes, Compatible: yes, In Use: no
Memory: 128 MB dedicated video + 0 B dedicated system + 32 GB shared system
Outputs:
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
SharpDX.SharpDXException: HRESULT: [0x887A0005], Module: [SharpDX.DXGI], ApiCode: [DXGI_ERROR_DEVICE_REMOVED/DeviceRemoved], Message: The GPU device instance has been suspended. Use GetDeviceRemovedReason to determine the appropriate action.
at SharpDX.Result.CheckError()
at SharpDX.Direct3D11.DeviceContext.MapSubresource(Resource resourceRef, Int32 subresource, MapMode mapType, MapFlags mapFlags)
at SharpDX.Toolkit.Graphics.Buffer.GetData(Buffer stagingTexture, DataPointer toData)
at SharpDX.Toolkit.Graphics.Buffer.GetData[TData](Buffer stagingTexture, TData[] toData)
at SharpDX.Toolkit.Graphics.Buffer.GetData[TData](TData[] toData)
at #=zqWD12ke1rBJ3uKfGg6X7Ob7tdKJ$rgLT6JLm5BI=.#=zEIu0xkRNTPhl(Int32 #=zIWFFQYY=)
at #=zqWD12ke1rBJ3uKfGg6X7Ob7tdKJ$rgLT6JLm5BI=.#=zHB1gqxCHIXUQhF6HQA==()
at #=zDT_YCDmfrX8JMij6udLDfkNHY9vFk$PNJw==.#=zKHrijepPO5a0nJNuTA==()
at #=zBzBST7CIex1FhLe4PN2seArbG1cUpVdPnw==.#=zSz5YiYY=()
at #=zBzBST7CIex1FhLe4PN2seArbG1cUpVdPnw==.#=zglCjlpMOA_ZioQTIeg==()
at #=zBzBST7CIex1FhLe4PN2seArbG1cUpVdPnw==.#=zApQRUVg=()
PostPosted: Wed Jan 20, 2021 1:40 am
Do you have the latest NVIDIA drivers?
PostPosted: Thu Jan 21, 2021 5:16 pm
I actually did have a driver that needed to be installed. I will test it and see if it is fixed. Thank you for the reminder.
PostPosted: Thu Jan 21, 2021 5:51 pm
It happens more frequently now. Any advice?
New error message after installing latest NVIDIA driver:
ENVIRONMENT
.NET: 4.7.2.528040
CPU count: 20
GPU Information:
Outputs:
PROCESS
Running in 64 bits
EXCEPTION
File comment: Driver_name
PostPosted: Fri Jan 22, 2021 8:29 am
The crash happens in a code related to the head tracking. Try to disable this feature. Will the issue persist?
PostPosted: Mon Jan 25, 2021 3:35 pm
Thanks for your reply!
Head tracking has already been switched off when I received these crash notes, but you're correct that once it was switched on Mocap Studio crashed immediately (was much worse).
PostPosted: Mon Jan 25, 2021 3:45 pm
It just crashed while tracking resolution was on low too.
Concerning.
Error_7 (low resolution tracking, with maximum power setting).png [ 251.63 KiB | Viewed 44727 times ]
PostPosted: Tue Jan 26, 2021 12:55 am
No problems in other software?
Probably your card is underpowered and this leads to issues under high load. Check all connection(s) of your card (PCIe slot, power etc), ensure they are firm.
Can you disable integrated Intel graphics? Probably there is some conflict between the two.
PostPosted: Thu Jan 28, 2021 7:28 pm
It does not crash when I use 'Old tracking algorithm' under 'Advanced Tracking Settings'.
Is this the same quality? Does it lower the accuracy? It seems to be very similar.
PostPosted: Fri Jan 29, 2021 1:49 am
yes, the quality and accuracy are the same.
Old algorithm uses GPU less intensively, so this may hint that there are some hardware issues under high GPU load.
There may be not enough power or card is overheating.
You can try using GPU-Z to monitor card temperature and compare workloads for different options.
Users browsing this forum: No registered users and 119 guests
