PostPosted: Thu Apr 09, 2009 4:24 pm
Hi, I am trying to run IPI recorder however ho idea why It crashes every single time I try to open it, running on XP SP3 with NET 3.5 SP1, there's no real message except for a a debug trace stack, however I have been able to record 1 camera with another software I have, but I want to try out with 2-3 cameras ( I have them here so why not )
since ipi-recorder is really not working, can I just use 2 programs and record the sources, however reading around it seems that the images in IPIrecorder do not have a standard format, ( maybe I am wrong ) I understand that they save both images on a linear fasion ( img1, img2, img3 , img1,img2,im3 etc )
now since I can't make ipi recorder work, is there any option to record from 2 cameras ? or if I have 2 video files separated can I multiplex them or something so IPI can use them ?
Thanks !
PostPosted: Thu Apr 09, 2009 9:53 pm
It would help us to debug this problem if you could post here the stack trace from crash.
Also, I need to know your camera model.
Unfortunately I do not know any alternatives for synchronized multi-camera recording. If you know any alternatives, please share your knowledge.
PostPosted: Thu Apr 09, 2009 11:00 pm
well there are programs that can record from different sources at the same time, however either I do not understand the IPI studio, or I am mistaken.
my question is, can I load 2 different video files at the same time on IPI studio, because when I open the first video file, and I try to open the second it does not allows me to open it, that's why I was under the impression that you have a format where you combine the 2-3-4 images together, if that's the case, then there's not much I can do about it.
however, if I can load 2,3,4 videos, then I could try using other programs that allow to record at the same time from different sources.
can you please explain me if it is case #2 how do I load video from 2 different video files on ipi studio ?
PostPosted: Fri Apr 10, 2009 12:35 am
There is no way to load two or more video files in current version of iPi Studio. It only works with single multi-view video file (all views side-by-side).
PostPosted: Fri Apr 10, 2009 3:05 pm
I placed how to record from 2 outside sources on the tutorials part.
PostPosted: Wed Apr 15, 2009 3:04 am
I had exactly the same problem. (two video cameras - logitech and creative). Additional Creative software possibly made this. Not drivers itself. After fresh install, without additional software, iprecorder starts to work.
PostPosted: Fri Apr 17, 2009 6:15 am
Latest version (1.0.1.30 beta) of iPi Recorder should fix this problem.
Users browsing this forum: No registered users and 108 guests
