It is currently Tue Oct 27, 2026 9:34 am
 Post subject: Blender Export
PostPosted: Wed Nov 02, 2011 2:08 am
exported rig has z-up problem. i have to rotate it.
also foot is not parallel to floor.
 Post subject: Re: Blender Export
PostPosted: Thu Nov 03, 2011 2:45 pm
Yes for blender I have seen this..Looks like a funny rotation bug.
PostPosted: Sat Dec 24, 2011 1:02 pm
Is this still a bug? Has it been dealt with?
PostPosted: Thu Mar 15, 2012 8:45 am
The export seems geared for the old version of Blender 2.49b, the new versions of Blender 2.6+ import bvh by default expects the rig to be -Z Forward, Y Yp, but you can change this to Y forward Z Up in the import settings. The only bad thing about this method is if you prefer to do some clean-up in bvhacker then your figure is half in the floor and editing work is a bit more of a pain you have to turn off the ground plane and get funky with the camera, but re-orienting into Blender in the new version is not very difficult.
It would be great to have the choice between exporting the Blender Figure in 2.49b orientation or 2.6+
I'd honestly like to work with my custom rig, but sadly when you go into edit mode the rig completely loses its orientation.
PostPosted: Sat Apr 28, 2012 6:01 pm
Can someone assist me with Blender? When ever i import my file to blender and try and bind it to my rig, its totally stuffed.
Here is a screengrab:
The upper body is fine, but the lower body is the opposite direction and when i go to try and use the Fix twist button,nothing changes
Any help or support would be appreciated.
PostPosted: Thu May 03, 2012 11:54 am
To a_haouchar
I think the bone axes on your rig and on ipi-soft standard rig are different. Change bone axes in your rig (Crtl+R in edit mode)/
PostPosted: Mon May 14, 2012 1:17 am
Thanks but i tried that.Changes but still bad
