PostPosted: Mon Mar 24, 2014 8:13 am
I opened IPI recorder today with 4 ps3 cams connected and the 4 camera screens in the display are black, however when i record there is a single frozen image recorded for each camera below is the trace from ipi recorder
thanks
Steve
my system is
intel i7 lap top 16gig ram win 7 home premium sp 1
trace_20140324_150945.txt.gz [4.75 KiB]
Downloaded 877 times
PostPosted: Mon Mar 24, 2014 10:33 am
As reported in the log, you have connected more than 2 cameras to a single USB controller.
Either try different USB port combinations until you find the working one, or reduce the frame rate to 30-40Hz.
Did you previously record with 4 PS Eyes on this laptop?
PostPosted: Mon Mar 24, 2014 10:55 am
Yes i have successfully used this laptop many times for capture, despite the warning about the cameras all being on one controller
there are 4 usb plugs on the case two either side but i've never understood what the device manager info means
see attached
I tried to connect one camera but this also just gave me the black screen and frozen recorded image i get with the four connected
Steve
PostPosted: Mon Mar 24, 2014 11:05 am
Here is the trace for one camera
Steve
trace_20140324_180335.txt.gz [3.04 KiB]
Downloaded 854 times
PostPosted: Tue Mar 25, 2014 12:02 am
One camera does not work - this clearly indicates some problem with data transfer. In the log, I see that only 1 invalid frame goes from the camera and nothing more.
Please, try reinstalling the PS Eye driver. Uninstall it (search "iPi" in Programs and Components), and download and run the standalone installer:
http://files.ipisoft.com/drivers/PlayStation3_Eye_iPi-x64.msi
Regarding connections. It looks like you have 2 USB 2.0 controllers and 1 USB 3.0 controller. However, the Device Manager cannot show the number of USB ports and how they are connected to USB controllers. If the laptop has both USB 2.0 (usually black/white ones) and 3.0 (usually blue ones) ports, then at least 2 controllers are available. Use USB 2.0 port(s) to connect 2 cameras, and USB 3.0 port(s) to connect another 2 cameras. If the laptop has only one port for 2.0 or 3.0, then use USB hub to extend the number of the ports.
PostPosted: Tue Mar 25, 2014 3:43 am
I did as you directed above and uninstalled and reinstalled the camera drivers but I'm afraid it did not work attached is the trace for 2 cameras
Steve
trace_20140325_103915.txt.gz [3.72 KiB]
Downloaded 869 times
PostPosted: Tue Mar 25, 2014 3:49 am
Do you have any problems with cameras indicated in Device Manager (exclamation icon on the device)?
PS Eye devices are located under the "Imaging devices" tree node.
PostPosted: Tue Mar 25, 2014 4:03 am
no there is no alert on them
see attached
Steve
PostPosted: Tue Mar 25, 2014 4:23 am
Try to find and install the latest USB drivers for your laptop.
If you are connecting with USB extension cable, try without it.
Have you tested all your cameras one by one, whether some of them work?
