It is currently Sun Nov 08, 2026 10:46 pm
PostPosted: Thu Feb 17, 2011 12:02 am
Yay! Our GTX 460 arrived today. Will try to install it before the weekend.
PostPosted: Sat Feb 19, 2011 10:17 am
I'm curious to hear how many seconds/frame it processes.
I got my cameras yesterday and tried them out last night. I'm really disappointesd. I could only get 50fps with 4 cameras and 30 fps with 6 cameras. Since webcams don't have shutters, that means that there's a 1/30 second integration per frame and lots of motion blur (which I hear ipisoft isn't good with).
This may end up too expensive for me right now,
Michael
PostPosted: Sat Feb 19, 2011 11:16 am
I was wondering how many USB controllers you have in your computer. Most computers have two on-board controllers, and you may need to experiment with different USB port combinations to get the 'two camera per controller' ratio. To get six you will likely need to get a separate USB controller to handle the two additional cameras. Also, you mention a RAID 0 drive. Is this a drive separate from the one with the operation system? iPi recommends that you do not record to the same drive that the operating system is on.
In my experience, you should be able to get 60 fps from four cameras with a fast quad core and a separate 7200 rpm SATA (non-RAID) drive for recording. To get six cameras to work with a quad core, you will very likely need to an SSD to record to. (Contrary to iPi official specs, which recommends a six core system for six cameras.)
BTW, until recently, my system was a i7 quad core with 2 USB3/SATA 6 GB controllers and second internal 7200 rpm SATA. The OS is Windows 7 Pro. I was using one of the two on-board USB controllers for two cameras and one USB 3.0 card for two more, and the second USB 3.0/SATA 6GB card was for the internal SATA 6GB drive. This got me full res at 60 fps with no problem. I probably could have used the two on-board controllers for the cameras though, but I happened to have a second card in an old computer so I just cannibalized that.
When I bought two more cameras, I also upgraded the computer with an SSD (on the recommendation of another iPi user.) Now I'm using the on-board controllers and the two the USB 3.0 cards for the six cameras, and the SSD for recording. I did a bandwidth test after I installed the SSD and it seems like it will work even though my computer is only a quad core. I'll know for sure tomorrow.
Hope this info helps.
