It is currently Mon Nov 09, 2026 1:51 am
PostPosted: Wed Sep 24, 2014 8:46 am
I wonder if anyone has experienced their motion appearing slow once it is captured? It looks like the speed of the action is lowered at some point during the process. Any ideas as to why this might happen and what I can do about it?
Thanks,
Adnan Hussain
http://www.madguru.com
PostPosted: Wed Sep 24, 2014 6:18 pm
Do you mean after it's been exported? It's possible that you're interpreting 60 (PS Eye) or 30 (Kinect) fps at 24fps in you're animation program. This can have the effect of slowing down your motion. To correct this, you'll need to convert the data to the desired framerate. For example, I like to render my animations at 24fps, so after retargeting an editing my iPi mocap in Motion Builder I would re-plot the motions to my final skeleton at 24fps.
If you have no way to properly convert the framerate of your motions, try capturing at a lower framerate.
If you're seeing slow playback from inside of iPi Mocap Studio, I'm not sure what's going on there.
PostPosted: Thu Sep 25, 2014 12:27 pm
Thanks Greenlaw. I think this is exactly what is happening. Playback in iPi is fine. I think I just need to be more careful about bringing the data in with the correct framerate it was recorded at and then change the framerate.
Thanks!
Adnan
Users browsing this forum: No registered users and 61 guests
