It is currently Sun Nov 08, 2026 1:24 pm
 Post subject: 6 PS EYE
PostPosted: Thu May 08, 2014 6:13 am
Hi we just bought 6 USB PS eye cameras I have 6 ports but my mouse and keyboard occupy two, the four I can plug in are fine If I plug a multi port hub into two of my ports can I use them for two cameras each, or should I move to get pci cards if so can anyone point me in the direction of PCI USB cards that are actually individual hubs rather than 4 into 1 say ?
Nik
 Post subject: Re: 6 PS EYE
PostPosted: Sun May 11, 2014 11:48 pm
Hello, Nik
The number of cameras you can connect to your existing USB ports depend on the number of USB controllers. For 640x480@60fps mode you'll need 1 USB controller per 2 cameras. Most probably, you've got 2 USB 2.0 controllers. In that case, you can use 4 cameras at full 60fps speed, or 6 cameras (with hub) at a lower framerate, 40-50. If you need 6 cameras at 60fps, then go with PCI (or PCI Express) USB card. Amazon has plenty of them, for example:
http://www.amazon.com/SD-NECU2-3E1I-NEC-Chipset-NEC720102-Ports/dp/B000BL0ARQ
http://www.amazon.com/SY-PEX20045-PCI-Express-Controller-uPD720200-Chipset/dp/B00JOC6XDS
Before purchasing, consult our wiki on known compatibility issues between cameras and USB chipsets to avoid getting into troubles:
http://wiki.ipisoft.com/USB_controllers
USB chipset used in PCI(e) card is usually stated on the card's vendor website.
Users browsing this forum: No registered users and 161 guests
