It is currently Tue Oct 27, 2026 1:24 am
PostPosted: Mon Jun 04, 2012 12:51 am
Not a critical error but the user specified output directory seems to be ignored by the Converter tool. After setting the Output directory, Recorder proceeds to write the converted file to the directory where the source video exists.
For this test, I created a separate '2.0 Conversion' folder in the same folder with the original 1.0 video files. In Convertor, I selected the '2.0 Conversion' folder as the Output directory for each video but the converted files appears outside of this directory in the same directory with the original video files.
PostPosted: Mon Jun 04, 2012 4:36 am
Thanks for report. We'll investigate it.
PostPosted: Tue Jun 05, 2012 1:21 am
This issue is fixed in the new v2.0.0.11 release viewtopic.php?f=11&t=6076
PostPosted: Tue Jun 05, 2012 1:25 am
BTW did you know that you can select multiple videos at once for conversion? This makes sense when they are all made with the same camera configuration, and have similar background time interval.
PostPosted: Tue Jun 05, 2012 9:59 am
No I didn't know that. I've been converting the videos one at a time and I did think the procedure could be more efficient. And so it is!
Thank you for the tip and thank you for fixing this issue so quickly. :)
Users browsing this forum: No registered users and 24 guests
