It is currently Tue Jun 30, 2026 4:50 am
Post a new topicPost a reply Page 2 of 3   [ 25 posts ]
PostPosted: Wed Jun 06, 2012 1:58 pm
ppe wrote:
Nope. Whatever the problem was, it is now gone.
Good. Though some performance improvements were made in recent releases, they should not make a great difference. The specs you provided are more than enough for smooth iPi Recorder functioning. Just guess, maybe you had some other CPU-consuming activity at that time?
PostPosted: Wed Jun 06, 2012 6:39 pm
I get this error when I start up, but it seems other than that the program works okay
[Thread: Name='', Id=1, IsBackground=False, IsThreadPoolThread=False]
System.IO.FileFormatException: The image format is unrecognized. ---> System.Runtime.InteropServices.COMException: Exception from HRESULT: 0x88982F07
at System.Windows.Media.Imaging.BitmapFrameDecode.EnsureThumbnail()
at System.Windows.Media.Imaging.BitmapFrameDecode.get_Thumbnail()
at MS.Internal.AppModel.IconHelper.GetBestMatch(ReadOnlyCollection`1 frames, Size size)
at MS.Internal.AppModel.IconHelper.CreateIconHandleFromImageSource(ImageSource image, Size size)
at System.Windows.Window.UpdateIcon()
at System.Windows.Window._OnIconChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at MS.Internal.FrameworkObject.OnLoaded(RoutedEventArgs args)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
PostPosted: Wed Jun 06, 2012 7:18 pm
Will iPi Recorder 2.0 work with iPi Studio 1.0 or does it record to an un-usable format that only Studio 2.0 will be able to extrapolate?
PostPosted: Wed Jun 06, 2012 7:43 pm
I haven't had a chance to record in 2.0 yet but I believe it only saves the new .ipivideo format. Just curious but why would you want to use a Recorder 2.0 file in Studio 1.0?
PostPosted: Wed Jun 06, 2012 11:00 pm
Nope. iPi Recorder 2 produces records only in new iPiVideo format. iPi Studio 1 has no support for this format.
PostPosted: Thu Jun 07, 2012 3:09 am
Unfortunately, we cannot yet test iPi Recorder on Windows Vista (I conclude you have this OS version by your posts in another topic http://forum.ipisoft.com/viewtopic.php?p=11330#p11330). We will try to address this issue in the next update coming by this weekend.
PostPosted: Thu Jun 07, 2012 12:44 pm
Ok, thanks for the note on the posts btw.
At this time I can launch and use IpiRecorder 2.0 but I can't launch IpiStudio 2.0013.
And yes, it maybe be vista but I can't really upgrade this machine at the moment to Win7 or possibly 8 while im in the middle of another production. Trust me I would love to :)
PostPosted: Thu Jun 07, 2012 8:14 pm
I noticed on the download page that there is only one Recorder listed. Is this the one I need to download for use with the current version of iPi Studio then?
(BTW, running Windows Vista 64 on this laptop with 2 USB 2 Controllers)
PostPosted: Thu Jun 07, 2012 11:06 pm
You need to download from the Beta page: http://ipisoft.com/V2_0_beta.html
They always have the latest version posted there. After I download a new version, I archive it in a folder with the version number so I can rollback if I need to.
(Is rollback built into the program now? Sorry, I haven't checked.)
PostPosted: Fri Jun 08, 2012 1:46 am
There are two separate download pages. The main downloads page lists installers for v1 which is still selling. The beta downloads page lists installers for v2, which is currently in beta.
No. But we save all the released v2 installers. Later, we'll create wiki page where one could download an installer for any specific v2 release if he wishes.
Users browsing this forum: No registered users and 45 guests
