It is currently Tue Oct 27, 2026 11:26 am
Post a new topicPost a reply Page 1 of 2   [ 14 posts ]
 Post subject: ipiStudio crashes
PostPosted: Thu Jun 28, 2012 7:27 am
Hello,
When I use ipistudio it crashes during callibration process (but not only, also when I for example adjust cameras or do anything else), it seems it crashes after some time from startup...
I have 6 pseye setup, and pc configuration is
- win 7 home premium 64bit
- mainboard MSI (Z77A-g43)
- intel core i5-2320 3.00 GHz (quad core)
- Ram - 8 GB
- graphic card - Geforce GTX 560 Ti
- one 64 GB ssd drive
I don't know what more info I can provide, windows says only that program stopped working ...
Regards.
 Post subject: Re: ipiStudio crashes
PostPosted: Thu Jun 28, 2012 8:07 am
What version of iPi Studio do you use (see Help > About)?
Does this issue started from the very first use of the software or after one of the recent updates?
PostPosted: Fri Jun 29, 2012 12:19 am
hi,
I use 2.0.0.133
the problem started when I installed on new pc (conf as above). I didn't install any updates.
With my old pc it worked fine, it was dual core with vista home premium 64 bit, 4 gb ram, same graphic card
regards.
PostPosted: Fri Jun 29, 2012 3:00 pm
Can you please update to the latest 2.0.0.134 release and provide us with debug information from the brand new Unexpected Error Dialog when the error occurs again?
PostPosted: Mon Jul 02, 2012 1:08 am
Hi again.
Are you using the trial version of software? Your issue seems very similar to http://forum.ipisoft.com/viewtopic.php?f=5&t=6158
PostPosted: Mon Jul 02, 2012 1:30 am
I am using Standard Version (licensed to Tate Interactive). I have updated to version 2.0.0.134 and after crash I got dialog box with following information
iPiMocapStudio.exe - Błąd aplikacji
Aplikacja wygenerowała wyjątek, ktrego nie można obsłużyć.
Identyfikator procesu=0xef4 (3828), Identyfikator wątku=0xeb4 (3764).
Kliknij przycisk OK, aby zakończyć działanie aplikacji.
Kliknij przycisk ANULUJ, aby debugować aplikację.
OK Anuluj
Regards
PostPosted: Mon Jul 02, 2012 2:32 am
We suppose this issue may be related to activation.
Please send your license key to our tech support email Image, so we could find server logs for your key.
PostPosted: Mon Jul 02, 2012 3:42 am
hi
I have deactivated the license but it was still crashing...
regards
PostPosted: Mon Jul 02, 2012 4:44 am
to vmaslov
thank you very much for your help
the problem has solved.
i think it is due to modifying the date setting in my computer
(which i misread the installation guide at the beginning)
after i have formatted the hard drive and re-install the OS
the software works fine.
i would like to ask, does the Trial Version provide finger tracking?
i have record the video with finger movements and it doesn't fit onto the model.
Thank you very much,
Tom
PostPosted: Mon Jul 02, 2012 7:24 am
hello
what do you mean by:
" i think it is due to modifying the date setting in my computer
(which i misread the installation guide at the beginning) "
couldn't you just change the time in time settings - why would you reinstall windows ?
do you have similar problem ? I don't understand why you've written it under this thread ...
anyway thanks for help ...
Regards.
Users browsing this forum: Baidu [Spider] and 194 guests
