It is currently Tue Oct 27, 2026 4:38 pm
Post a new topicPost a reply Page 2 of 3   [ 25 posts ]
PostPosted: Wed Jun 06, 2012 6:59 am
Yes, trace would be great. And what exact version of iPi Recorder do you currently use?
PostPosted: Wed Jun 06, 2012 7:09 am
Attached to original message
v2.0.0.12
PostPosted: Thu Jun 07, 2012 6:26 am
Quick update - on the laptop, SDK 1.5 works perfectly.
Even detects calibration plane way better than I had on this machine which uses PrimeSense drivers, this is very strange.
PostPosted: Fri Jun 08, 2012 2:08 am
Aktion wrote:
Still got same issue with SDK 1.5 (removed any primesense/openNI drivers) - Kinects detected but This sensor is powered up. They are powered, moreover, worked perfectly 15 mins ago with PrimeSense drivers.
Can you please provide us a screenshot of how Kinects are looking in Device Manager when using Kinect SDK drivers?
PostPosted: Fri Jun 08, 2012 3:30 am
Let me reproduce it first - with PrimeSense drivers everything works so I deinstalled SDK 1.5 already.
PostPosted: Fri Jun 08, 2012 3:37 am
File comment: This is uninstalled everything with openni/kinect and installed Microsoft SDK 1.5
File comment: This is using Prime Sense driver from v1.3
PostPosted: Thu Jun 14, 2012 4:08 pm
2Aktion:
Today got the same "not powered" issue from once more customer by email. Later he wrote that they've bought another Kinect, and it works fine. So maybe it is some hardware problem in specific instances of Kinect. It is strange that it is also computer-dependant, as you say your Kinects work fine connected to laptop.
Anyway, your Device Manager screenshot definitely shows that there is some problem between your devices and Kinect SDK drivers. Instead of "Microsoft Kinect Audio Array Control" devices under "Microsoft Kinect" node there are "Kinect USB Audio" devices under "Other devices" node. You can find the "correct" picture in Device Manager on this page.
Also, here there is a sequence of connecting Kinect to PC:
    1. Connect the power supply for your Kinect to an external power source.
    2. Connect the Kinect to a USB port on your PC and wait for Windows to recognize it.
    3. All the drivers, including audio, will load seamlessly.
I think, order of steps 1 and 2 can make a difference.
PostPosted: Tue Jul 17, 2012 11:48 pm
I'm getting this problem as well. One Kinect is recognized, the other tells me to plug in the power (and of course it is plugged in). They're both recognized in Device Manager. I'm using the latest software 2.0.0.13. They're both Xbox Kinects. Any ideas?
PostPosted: Wed Jul 18, 2012 3:27 am
I just tried it on two different computers, same issue. I reinstalled ipiRecorder version 1 and it works fine. I guess Microsoft wants us to buy MS Kinects to use their SDK? Is there any confirmation that this might fix the problem?
PostPosted: Wed Jul 18, 2012 1:32 pm
As I can remember, there were no reports about this issue from Kinect for Windows users. However, I cannot say for sure that they have no this issue at all. Most of our users have Kinects for XBOX and they are working normal with the new version.
I only may suppose that there is some little "defect" in particular instances of Kinects that had no effect with Kinect SDK 1.0, and started failing with Kinect SDK 1.5 (which is used by Recorder v2). Try switching to PrimeSense drivers instead of Kinect SDK.
Users browsing this forum: No registered users and 108 guests
