It is currently Sun Nov 08, 2026 6:07 pm
 Post subject: The T pose
PostPosted: Sat Jul 21, 2012 1:41 am
I use Poser Pro 2012. The problem I encounter is that the BVH goes into the wrong place when loaded to the avatar in PP2012. I have tried to use the t pose on first frame from recorder setting, however this is not good enough, because frame 2 and onwards move from the T pose into the original position when recorded (could move a long way from the T pose on the X and Z). This causes nightmare in cloth room and Marvelous Designer.
You may already have the solution, but I do not know of it yet.
Suggestions:
In the recorder:
A) When you make the T pose could you have a silhouette which shows you the correct position in space to be on the screen.
B) Could the T pose automatically calibrate to the correct T pose position in space, either on the recorder or in studio?
Hoping for a positive solution.
 Post subject: Re: The T pose
PostPosted: Mon Jul 23, 2012 1:42 am
Please check if recentering coordinate system on character resolves your problem. See this topic:
http://forum.ipisoft.com/viewtopic.php?f=5&t=6166.
PostPosted: Mon Jul 23, 2012 3:22 am
Thanks works great.
Users browsing this forum: No registered users and 74 guests
