It is currently Thu Nov 05, 2026 11:25 am
PostPosted: Sun May 24, 2009 4:42 pm
Calibration
http://www.youtube.com/watch?v=r5ErzUHZDT4
FOV 72.20 degrees (logitech 9000)
1st camera height 2.20m.
If you calibrate with this video, you will feel where is the ground.
This dirty video has worked fine. I need some lighting...
http://www.youtube.com/watch?v=9cSLpqDrfSc
I'm impressed how works this software. I haven't got any experience in mocap and in a few intents i found the way (thanks to lightdog).
PostPosted: Sun May 24, 2009 5:03 pm
cool thanks for sharing
PostPosted: Fri May 29, 2009 11:59 am
Calibration 640x480 25fps
http://www.youtube.com/watch?v=zTxAt6i9Jgo
FOV 72.22 degrees (logitech 9000)
1st camera height 1.54 metres
A high speed movement video 640x480 25fps
http://www.youtube.com/watch?v=G5b-NQEErfA
I got very good results supervising the track and handposing position calculation errors but i can't share them cos my trialtime has expired :(
www.PelotaGame.com, my hobby.
PostPosted: Sat Jun 27, 2009 3:57 pm
Here are tracking results rendered with 3dsmax.
http://www.youtube.com/watch?v=rXR5tpk1SXc
PostPosted: Sat Oct 24, 2009 1:06 pm
Great ! Hyper clean calibration video sems to be the secret.My one had reflections all over, so I spoiled my 3 cameras tests.
is there a way to download your tests from You tube ? is there a way to do so ? would you allow it ?
because it could be very useful for our own tests with Ipi.
Luiz
PostPosted: Sun Jul 18, 2010 6:46 am
I've edited these videos to work in IPI but due to the low res the results are a little flakey at times, otherwise they should work
txesmi if you wish me not to share these just let me know, I don't know how long I'll have these up so this link may not work in the future
http://mpmaxwell.com/IPI_AVIS.zip
apart from these and the IPI tutorial I've had to go out and buy 4 PS3 cams and extension cables, a fair cost for just testing something. I recommend making more files available for people who wish to try the program out first
PostPosted: Sun Jul 18, 2010 7:13 am
For those interested I've uploaded a movie of my results using these videos, a tweaked the punch a little but still pretty raw
http://mpmaxwell.com/IPI_TestAnim.mov
I have to say I'm pretty impressed with this program and will most likely buy it at the end of the trial, just need to see what I can pull off in my tiny flat when the cams get here
PostPosted: Mon Jul 19, 2010 1:34 am
That's a cool test!
And good idea about uploading test files for others to play with. I've been doing that at the NewTek forums, mainly for others to try retargeting iPi .bvh files to characters in Animeeple, and then exporting the data as .fbx or .dae in other 3D packages. So far one user go the data into Max, and I've had good luck moving the data on a stock Animeeple character to LightWave but only if I use the optional .fbx exporter. I think a few other users are testing the files in other 3D applications (awaiting results.) It's been fun turning the tests into a community R&D project, and it saves me a lot of time testing things by myself.
I'll post some of my test files here later this week and see what interesting things turns up. :)
PostPosted: Mon Jul 19, 2010 1:39 pm
Thanks G!
It's a shame the IPI guys dont have a page full of different calibration and capture videos to test with, I'm going loopy waiting for my cameras to arrive:) Time on the trial period's running out too!!:(
If you have any videos to share it would be greatly appreciated, cheers
PostPosted: Mon Jul 19, 2010 3:32 pm
I'm planning to do another capture session this week, and I'll see if I can upload a link to some of it in the tutorial section (if it isn't too embarrassing.) :)
Users browsing this forum: No registered users and 29 guests
