It is currently Tue Oct 27, 2026 6:10 pm
PostPosted: Tue Nov 27, 2012 2:53 am
Hi guys,
with new version (ver. 2.1.1.18) of iPi Recorder and new Kinect SDK (1.6) my Kinect for XBOX stopped working. Since I updated iPi recorder my Kinect just disapeared from Devices window in iPi recorder. After reconnecting it pop-ups the warning "The USB connector to which the Kinect sensor is attached does not have sufficient bandwith. Or two Kinects are using one and the same USB.".
Just announcing my Kinect is connected to regular single USB slot and I also tried switching and reconnecting it and restarting.
Thanks for any help.
File comment: Error message in iPi Recorder.
PostPosted: Tue Nov 27, 2012 3:05 am
Are some of these PS Eye cameras attached to the same USB controller as the Kinect? Have you tried to unplug them?
PostPosted: Tue Nov 27, 2012 3:20 am
Yes I did, but still same error message. :/ until i updated it was working perfectly with no problems.
PostPosted: Tue Nov 27, 2012 5:50 am
Could you please attach the trace log from Recorder? It may contain some information useful for investigating this issue.
PostPosted: Tue Nov 27, 2012 7:34 am
To at least see the kinect, I had to multiple times click on add camera button and then cancel; after kinect finally appears it has the mentioned message.
File comment: requested logfile
trace_20121127_152814.txt.gz [8.41 KiB]
Downloaded 867 times
PostPosted: Tue Nov 27, 2012 8:14 am
Please make a screenshot of Device Manager, in Devices By Connection view, expanded to show the devices for Kinect:
  • Microsoft Kinect Camera
  • Microsoft Kinect Audio Array Control
  • Microsoft Kinect Security Control
PostPosted: Tue Nov 27, 2012 9:38 am
FYI :)
PostPosted: Tue Nov 27, 2012 9:42 am
now I realised where was the problem
Kinect camera was under PrimeSense, so I removed all primsense OpenNI and nite drivers and now everything works fine
Users browsing this forum: No registered users and 135 guests
