It is currently Sat Aug 15, 2026 6:05 am
PostPosted: Sun Jan 27, 2013 9:55 am
I'm try to test ipimocap software, but I can't load kinect device at startup.
I'm on macbookpro over bootcamp ( no probleme with other software kinect/mocap/scan ...) and use an xbox kinect.
In tool setting all driver for kinect is load ...
I've only "FaceTIme HD camera build"( intern camera of macbookpro) appear at start of ipirecorder ....
I don't find any issue , I test to removed all kinect , openNi , primsens driver, re-install all ......
Help needed.
I attache showl trace file
thx.
Diez
www.paradigme.tv
bug_kinect_not_appear_diez.gz [2.92 KiB]
Downloaded 700 times
PostPosted: Mon Jan 28, 2013 10:26 am
Hello!
Could you please try the following:
1. Make sure that AC/DC adapter is connected
2. Try different USB ports on your laptop
3. Re-install Kinect SDK from the following link:
http://www.microsoft.com/en-us/kinectforwindows/develop/developer-downloads.aspx
(Download Latest SDK button)
4. If you're here and still have no success then please provide us with screenshot of Control Panel (can be called right from iPi Recorder using corresponding item in tool menu) with expanded node Microsoft Kinect:
(Microsoft Kinect for XBOX devices should be connected to the computer at the screenshot moment)
Users browsing this forum: No registered users and 18 guests
