It is currently Sun Nov 08, 2026 4:19 pm
PostPosted: Fri Aug 14, 2009 3:22 pm
one cam it works, albeit at 5fps. but cams, both identical id like to add, and it says "One or more arguments are invalid"
it is possible that your camera does not support selected resolution / framerate please try..... but i know that these settings are low. and i cant go any lower.
PostPosted: Sat Aug 15, 2009 11:47 am
What cameras do you use?
PostPosted: Wed Nov 25, 2009 5:17 am
Now i got the same problem with philips spc1030nc webcam. I can't change resolution or frame rate with ipi recorder... Igot always the same advertising : "one or more arguments..."
It's surprising me because it worked the days before. I've changed my notebook drivers yesterday i'll look at that.
www.apside3d.fr
PostPosted: Wed Nov 25, 2009 5:29 am
I've try on another computer and it seems that it is the news version of ipi recorder who create the problem.
The camera work well with the previous version and not with the new version.
www.apside3d.fr
PostPosted: Thu Nov 26, 2009 12:42 pm
We only tested it with Philips spc900 so it is possible that there is some incompatibility with Philips spc1030nc.
As a workaround, you can completely uninstall Philips drivers and use the camera with standard Windows drivers. Philips spc1030nc is a UVC (http://en.wikipedia.org/wiki/USB_video_device_class) device so it should work without Philips drivers.
PostPosted: Mon Nov 30, 2009 6:01 am
thanks ! I'll try today and report the result here !
www.apside3d.fr
PostPosted: Mon Nov 30, 2009 11:15 am
Ok, the spc 1030nc'webcam work with the standard usb audio\video device drivers from windows.
i've find with the ip camera calibration tools something between 78° and 81°.
I can try the next step :calibration...
www.apside3d.fr
PostPosted: Wed Dec 02, 2009 8:02 am
According to Philips official spec, spc1030nc has a FOV of 80 degrees.
http://www.consumer.philips.com/c/webca ... prd/en/hk/
Users browsing this forum: Baidu [Spider] and 136 guests
