It is currently Tue Oct 27, 2026 7:19 am
 Post subject: ipisoft for children
PostPosted: Tue May 07, 2013 11:52 am
i tried to capture my son. because ipi model body ratio does not fit him tracking is not successful as when actor is me. is it possible to change bone sizes? you can see the problem in this image;
http://www.flickr.com/photos/40553949@N06/8718524108/
 Post subject: Re: ipisoft for children
PostPosted: Tue May 07, 2013 1:55 pm
This is a widely discussed problem. We plan to add more customization capabilities regarding actor model in v3.
PostPosted: Tue May 07, 2013 11:23 pm
it is bad to hear that it will be a paid feature :-) at least can you do that; while adjusting actor size, can you change ratio automatically. when setting actor size as 1.0 m it is certain that proportions will not work. i know exact solution is not linear but you can set optimum parameters.
http://www.idrawdigital.com/2009/01/tut ... oportions/
PostPosted: Wed May 08, 2013 2:33 am
Nice chart :) It may be helpful.
You should understand that we cannot give all the new features for free. We make living from the selling of the software.
PostPosted: Wed May 08, 2013 12:29 pm
It's tricky. My daughter and I did this when she was five years old.
Mocap with small child (1 meter tall)
I had to scale the model down to 1 meter. It worked for the most part but this was probably the trickiest tracking test I've ever had to do in Mocap Studio.
Actually, this example was created back in iPi Desktop Motion Capture 1.0. In Mocap Studio 2.0, I find that the bending spine issue described elsewhere makes it a little harder to track in 2.0. I think a fully adjustable rig would solve this issue.
PostPosted: Thu May 09, 2013 4:59 am
yes i understand it for new features. but this is related with height of character. if you give a variable that can be set 1.0 m it should work for 1 m human.
P.S. i am trying to get this feature free :-) don't make it the the best for now. at least add simplest feature that makes it better. at v3 you can add fully customizable skeleton. so we can use it also for nonhuman creatures :-)
i will try track it twice. one with arms fitting on with others fitting. then i will combine results.
PostPosted: Thu May 09, 2013 11:06 am
In the mean time, you may need to resize the skeleton for different actions by the performer, adult or child. I'm having to do this for our current production--sometimes I even have to change the scale in the middle of a motion to keep the spine from bending sideways.
For example, when I'm in a standing pose, I need to use a taller actor for tracking to keep the feet on the ground but when sitting or crouching, the actor needs to be shorter to keep the spine from bending and to prevent the feet from breaking out of the scanned volume. It's not an ideal situation but with patience and practice, it's doable and not terribly difficult. Thankfully, many actions (i.e., almost anything but my daughter's crazy cat dance in the above example above,) should track fairly smoothly with the current system.
Hopefully, we'll have an easier time with this in 3.0 but I imagine that's still a ways off.
Users browsing this forum: Baidu [Spider] and 31 guests
