Groot wrote:
The only trouble I have is (1) one arm sometimes gets "lost" -- it ends up behind me or at a funny angle
There can be different reasons for this and different strategies for fixing this.
1) It is possible that arm was occluded. Using 4 cameras can help to mitigate this problem. For tracking to work correctly, it is preferable that each arm should be visible in at least 2 cameras all the time.
2) It is possible that arm position was recognized incorrectly during pose transition. Transitions usually take small time - like 2 or 4 frames. In this case, you can manually correct the pose in few problematic frames and repeat tracking.
3) There could be a problem with dim lighting or background clutter, so that software mistakes actor's arm for part of background. In this case, it is recommended that you improve lighting or background and re-shoot the video, because manually editing many frames can be too time consuming.
Groot wrote:
and (2) If I sit or lie on the floor, I don't get good results at all.
We currently research this problem. Preliminary I can say that it can be related to placement of cameras - tracking sitting or laying actor is not working well with traditional placement of cameras (one center, two on sides). It probably should work better with 4 cameras. Future versions of our software may improve on this.
