It is currently Sun Nov 08, 2026 5:47 pm
PostPosted: Thu Sep 12, 2013 11:31 am
Hello Everybodys my english is not great but i'm trying explain my problems with screenshots
I am use Single Kinect Sensor from XBOX 360
I dont do any complex anim just simple slow stand dance or some kinda boxing hehe
All the time i got problem with down part of animation like a "floating" also angle of legs are bit starange i am not "ET" :P
I though i am too fat for it but i testing it with friend much lighter than me ;p
Im trying fix it with Jutter doesnt help.
Please help guys :)
My Work Space
There is errors no clue what im doing wrong.
Sometimes it's like a Lighter this
And sometimes this .
Once again sorry for bald english.
Please Help
Regards
PostPosted: Fri Sep 13, 2013 1:27 am
The "falling" issue is most probably caused by the improper ground detection. For the stable ground detection the ground pixels should take about 1/4 of the depth image. On your screenshot it is far less. To enlarge the ground area you can do one or more of the following: tilt the Kinect down, move it away from the actor, use wider capture area.
The last screenshot demonstrates a typical tracking error. Usually it can be easily cleaned up.
http://wiki.ipisoft.com/Clean-up
PostPosted: Fri Sep 13, 2013 1:55 am
So with this problem :
http://img4.imageshack.us/img4/2853/8yx6.jpg
I need make more space for ground ?
I mean strange angle of legs to body.
PostPosted: Fri Sep 13, 2013 7:03 am
Sorry for doubled post but i dont see edit option. Back to my problem
I make more space for ground like u said:
But problem still happen please help still no clue what im doing wrong ;/
Regards
PostPosted: Fri Sep 13, 2013 7:59 am
Since you haven't posted an image from the capture data it's a little hard to tell but are you stand near a wall or leaning against furniture? In the image near the top, it looks like something is against the Actor's legs. I'm just wondering because when large objects are too close to the performer, the Kinect cannot construct an accurate human form--everything blobs together.
It's recommended that you stay away from large furniture (sofas, beds, wardrobes, etc.) and walls.
I don't know if that helps you but good luck.
PostPosted: Fri Sep 13, 2013 10:55 am
I still got this problem i just make screens from video maybe it can help decide what mistake i made or something upper part of body works great only feets dont want record tracking corectly .
I saw a lot of videos from single kinect on you tube and they have more strange bacground for record.
Im trying setup actor as close to depth scan as possible :(
Feet's still got this wired issue and legs a lil too ;/
Please help me figured it out guys ;(
Regards
PostPosted: Fri Sep 13, 2013 11:01 am
This may be improper height of the model. Try reduce the actor's height on the Actor tab.
If you could send us your video, it would be easier to guide you.
PostPosted: Sat Sep 14, 2013 2:02 am
Hello guys i catch an video file for tests!
https://ia601007.us.archive.org/11/item ... ontest.rar
.iPiVideo File
Please help me with figured it out :)
Regards
PostPosted: Sat Sep 14, 2013 10:44 am
Sorry once again for doubled post guys i just dont see any "edit post" button on page .. no clue why.
Vmaslov i upload for you ..my record from ipi recorder
Here is link https://ia601007.us.archive.org/11/item ... ontest.rar (555 Mb Rar)
Please test it and tell me what im doing wrong .
Please help me .
Regards
PostPosted: Sat Sep 14, 2013 11:32 am
Already downloaded.
You can edit your posts during first two hours after posting.
Users browsing this forum: No registered users and 62 guests
