It is currently Sun Nov 08, 2026 6:58 pm
PostPosted: Wed Oct 30, 2013 12:59 am
Hi All,
I new to ipisoft. I have 1 kinect for windows that I track my motions with.
I made very short animation tracking. I start with a T pose and bend over to pick something up (no props just make it like I pick something up) and lift it over my hand and return to put the it back on the floor. It all works great until the end of the scene where my left leg when bending is twisting after (tracker is twisting my actor left leg). The thing is that I bend also at the beginning and no twisting occurs. Is there a way to fix this problem like fixing IK of leg manually. I don't want to shoot the scene again :-)
Thank u in advace
Eyal
PostPosted: Wed Oct 30, 2013 5:47 am
Please read about clean-up in our wiki:
http://wiki.ipisoft.com/Clean-up
In short, you need to manually correct the pose in incorrect frame with Rotate/IK tools, then hit Refit Pose for more accurate correction, and then track backward/forward from this corrected frame to correct other frames.
PostPosted: Wed Oct 30, 2013 2:18 pm
Thank u for your answer. But When I repose the foot via IK and enter refitpose I ger a twisted leg for this pose...
PostPosted: Thu Oct 31, 2013 12:14 am
Have you turned off trajectory filtering (decrease it to zero value) before doing Refit Pose? If not, then you must be seeing already filtered pose, which considers neighbour incorrect frames, and not the exact result of Refit Pose.
PostPosted: Sun Nov 03, 2013 10:18 pm
I see
Thank u :-)
Users browsing this forum: No registered users and 145 guests
