Quote:
Do you have the "Auto detect initial camera positions" option enabled?
I did have it enabled at the first run, I turned it off after it failed and ran the calibration again. I normally have the cameras setup as close to the original placement as possible. But since my studio is shared I have to breakdown the cameras. However, I do save the .xml files.
Quote:
manually move the cameras to their approximate positions before running the calibration.
In theory, shouldn't using an existing .xml file that is close to the placement of the camera be the same as manually moving the cameras within the software?
So far the calibration has failed each time giving the same results. I have performed 2 calibrations passed with the flash light and both have failed. I went back a few months back using footage I have successfully created a .xml file and did some test, now the calibration for those footage are not working.
