It is currently Mon Sep 21, 2026 6:02 am
PostPosted: Thu Feb 06, 2014 10:40 am
Hi i am having trouble getting 30 frames per second on my new laptop a Lenovo Y510p.
Core I7, 8GB Ram, USB 3.0 and USB 2.0 ports.
I have tried Kinect SDK 1.5, 1.6, 1.8 and the psdrv3.
I have tried several versions of the recorder, and I can only get about 24 fps.
trace_20140206_184002.txt.gz [2.58 KiB]
Downloaded 714 times
PostPosted: Fri Feb 07, 2014 6:39 am
Thanks for the log, it does not contain any unusual records.
Did you try all available USB ports?
What if you set 320x240@30Hz mode?
PostPosted: Fri Feb 07, 2014 7:32 am
I tried all available USB porte, and I tested my sensors on my Surface Pro, My HP6550b and my Lenovo 3000 N100, and I got a solid 30 fps. So I tried jpeg compression and 320x240 and I even installed the K-lite codec pack to see if it was my avisplitter, but nothing helped. But during the installation of K-lite i noticed the fps hit 30, so I tried to run a ressource intensive program alongside ipirecorder, in this case Broken Age. Suddenly the framerate jumped to a solid 30 frames, and stayed there, I could even plug in my second Kinect and got 30 frames on both cameras, but only as lang as I was running Broken Age at the same time. My conclusion must be that there is a problem with powersaving on my laptop. By the way I am running Windows 8.1.
Users browsing this forum: No registered users and 117 guests
