It is currently Mon Nov 09, 2026 12:17 am
 Post subject: jitter removal bug
PostPosted: Sun Jun 01, 2014 7:36 am
Hello iPiSoft,
It seems to have a problem when using jitter removal with data from Ps Moves. From time to time the head or hand will simply face a bad direction which results in very high jitter.
 Post subject: Re: jitter removal bug
PostPosted: Mon Jun 02, 2014 1:18 am
I do not completely understand your problem.
Do the data from motions controllers contain irrelevant data (like spikes) from time to time?
Or does the application of motion data produce irrelevant rotation of a bone it is attached to?
Or does the application of jitter removal make the motions look worse?
FYI, iPi Recorder applies smoothing filters to motion data coming from sensors in order to supress the natural noise in measurements. So, the motion data stored in iPiVideo files are already smooth and do not require jitter removal. Jitter removal in Mocap Studio is intended for post-processing of optical-tracked data, not the data get from motion sensors. Normally, you can apply the data from motion controllers after jitter removal without making any damage to the smoothness of an animation. Moreover, jitter removal is not applied to the hand bones at all (because they are not tracked optically).
PostPosted: Thu Jun 12, 2014 1:13 pm
Hello vmaslov,
I thought jittler removal could be used with data from motion controllers. What I usually do is to add data from motion controllers after optically-tracked data has been taken care of so everything is fine. You may add the possibility in a future release to remove jittler from motion sensors data because sometimes the actor may move a little too much his hands or head. This could be taken care of later in an animation software but since you already do it for optically-tracked data this may not be a lot of work.
Anyway congrats for the amazing work you achieved with your soft.
Cedriq.
Users browsing this forum: No registered users and 64 guests
