It is currently Mon Nov 09, 2026 1:49 am
PostPosted: Sun Jun 05, 2016 11:13 am
I'm going to be getting a new iPhone soon to use as a hotspot for recording Kinect v2 cameras between two computers. It's easy to tell how much of my data plan will be used in a session if I decide to auto merge a distributed recording. What I don't know is how much memory from my data plan will be used during the recording. The copy/merge of videos can be worked around via thumb drives. A scene usually is about 300mb give or take for like 30-45 seconds. But, during recording, is there a way to know how much the hotspot is being taxed? I could blow through my monthly data service plan in a few short recordings and id like to know how much is being used during recording....of say 30sec - 1min of recording. A lot? Not too much?
PostPosted: Sun Jun 05, 2016 11:27 am
Also, can you distribute record without wifi? That would solve all of my problems if that were possible via Ethernet
PostPosted: Sun Jun 05, 2016 11:48 am
Distributed recording does not send any data to Internet or receive it from there. It's only local network transfer. So if you use a smartphone as Wi-Fi hotspot, none of your mobile Internet traffic is spent.
Sure, you can use cable (Ethernet) connection between PCs. This will provide you better speed for records transfer.
Also, another speed-up option is to transfer iPiVideo files via external drive and merge them later in iPi Recorder.
Users browsing this forum: No registered users and 62 guests
