It is currently Mon Nov 09, 2026 8:05 pm
PostPosted: Fri Dec 02, 2016 7:28 pm
The iPiSoft recorder crashes immediately on launch.
It gives me a long error message (will put here if requested) and can not be opened.
I've used the installer to repair and reinstall the program and I have run it as administrator and it will not launch
PostPosted: Sat Dec 03, 2016 12:24 pm
If it's the same error message you've dropped on support email, no need to duplicate it here.
From the message I see that your OS is Windows 8.1. Is that correct?
Do you use custom non-default UI theme for OS? If yes, try switch to default theme.
Users browsing this forum: No registered users and 47 guests
