It is currently Sun Nov 08, 2026 6:31 pm
PostPosted: Fri Jun 14, 2019 5:08 pm
My spec are Ryzen 2700x @4.0GHZ, 16GB of RAM, 1080TI 11GB, and SSDs for storage.
I'm getting between 5-10 FPS when I go into iPi Recorder. Please advise how to fix this issue.
PostPosted: Sun Jun 16, 2019 8:11 am
Most probably it's an USB issue. As you're on AMD CPU I guess your USB 3.0 ports are served by AMD USB controller. While Kinect 2 is known to work best with Intel and NEC controllers.
Anyway, try all available USB 3.0 ports. If no luck then you'll need to install a PCIe card with NEC USB 3.0 chip and connect to it.
PostPosted: Sun Jun 16, 2019 2:42 pm
Yeah I disconnected all my USB devices and tried all ports. After doing so it finally worked in one port, therefore, I can say the issue is resolved.
Users browsing this forum: Baidu [Spider] and 44 guests
