It is currently Sun Nov 08, 2026 5:36 pm
PostPosted: Fri Dec 06, 2019 3:39 am
video from different computers does not synchronize with each other ,how to solve ,Mr boss from ipi
team
PostPosted: Fri Dec 06, 2019 4:14 am
Are you talking about distributed recording? Which cameras?
Is there a constant or varying time shift between videos? Are there frame rate/frame drops issues during recording?
PostPosted: Fri Dec 06, 2019 4:31 am
we have 4 azure Kinect solution and 12 Logitech c922 pro solution ,and the issue happen when use ten Logitech c922 pro camera beyond three computer,yes distributed recording there is not rate/frame drops issues
PostPosted: Fri Dec 06, 2019 4:45 am
If the time shift you get is constant through the whole duration of a video then you can try to fix this with Build Combined Videos feature. Open a merged .iPiVideo file and adjust sync frames for individual cameras. Then save resulting video.
http://docs.ipisoft.com/How_to_Build_Synced_Multi-Camera_Video#How_to_synchronize_manually
If you wish you may share the problematic videos with me - those recorded on each PC, before merging. Probably I'll be able to give you more specific recommendations.
PostPosted: Fri Dec 06, 2019 5:00 am
thanks,this tools will be ok ,I will try it ,no frame drop is impossible ,I find the reason now ,because ,a computer use a ssd disk and other computer use 1tb hard disk ,and then remove the ssd disk ,use another 1tb hard disk ,solved ,thanks a lot
Users browsing this forum: No registered users and 126 guests
