It is currently Sun Nov 08, 2026 4:02 pm
 Post subject: Azure Kinects don't work
PostPosted: Thu May 28, 2020 10:58 pm
Hello.
I have tried free software version with 2 azure kinects.
Unfortunatelly non of them can record any pictures. (images are black, no point clouds or color images can be recorded).
Do you have any ideas why can it happen?
It works if I use standart Azure Kinect recorder-viewer.
PostPosted: Sat May 30, 2020 12:01 am
Have you tried to record with a single Azure Kinect connected? Does it work?
PostPosted: Tue Jun 02, 2020 10:17 pm
Hello. I tried to record with standart Azure software and it works.
Unfortunatelly, it doesn't work if I use IPiSoftware.
I tried one or 2 devices. The picture is just black
PostPosted: Wed Jun 03, 2020 8:49 am
What is the version of iPi Recorder?
Provide some screenshots of the problem - what do you see on the home screen, in "camera types" panel, on "Setup" screen after you select Azure Kinect and press "Record Video" button on the home screen.
Also please provide the log file. After opening the recorder, open the Trace window by pressing a small button in the top right corner (near window close button). Set log level to "Verbose". You may close or minimize the Trace window. Select Azure Kinect and press "Record Video" button. Then open the Trace window again and save the log to a file.
PostPosted: Sun Jun 07, 2020 10:15 pm
here is what I get if I connect one azure to IPIsoftware. Pictures are black and no way to change it
it works or for standart azure viewer
https://drive.google.com/file/d/1PofHEMGn0OBXwY-BzguOAS4JN9NtLlW4/view?usp=sharing
https://drive.google.com/file/d/14x7DIN7mHy7WO6UWomQRH1cP9D9CKOrE/view?usp=sharing
PostPosted: Mon Jun 08, 2020 2:22 am
Please also provide log from iPi Recorder as I described in my previous comment.
What is your PC configuration?
Did you try depth-only modes in iPi Recorder?
PostPosted: Wed Jun 10, 2020 1:43 am
As you can see, I tried many different configurations, but I get only black images.
Shall I be able to see some depth / RGB data?
Which configuration parameters do you need?
iPi Recorder 4.4.5.82
OS: Microsoft Windows NT 10.0.17763.0 (64 bits)
.NET: 4.7.2.528049
CPU count: 16
GC: workstation (Interactive)
Running in 64 bits
10:35:35.700: Information: [Thread=12] K4AVideoSource[000209301412]: Streaming stopping...
10:35:35.701: Information: [Thread=12] K4AVideoSource[000209301412]: Set stop event and join capture thread.
10:35:35.701: Information: [Thread=18] K4AVideoSource[000209301412]: Stopped background thread.
10:35:36.783: Information: [Thread=12] K4AVideoSource[000209301412]: Streaming stopped.
10:35:36.783: Information: [Thread=12] K4AVideoSource[000209301412]: Streaming stopping...
10:35:36.783: Information: [Thread=12] K4AVideoSource[000209301412]: Deiniting
10:35:36.783: Information: [Thread=12] K4AVideoSource[000209301412]: Deinited
10:35:38.004: Information: [Thread=1] iPiRecorder.Recorder.ViewModel.CameraSettingsManager: Applying camera settings from registry for [Azure Kinect K4A:000209301412]
10:35:38.007: Information: [Thread=1] iPiRecorder.Recorder.ViewModel.CameraSettingsManager: Camera settings applied.
10:35:38.159: Information: [Thread=1] #=z9xwQ2Y$ovMzdKL_DvKFTJClRWHGW: Created GPU camera rendering pipeline for Azure Kinect: depth: 640x576 (Depth)
10:35:38.313: Information: [Thread=1] #=z9xwQ2Y$ovMzdKL_DvKFTJClRWHGW: Created GPU camera rendering pipeline for Azure Kinect: color: 1280x720 (Jpeg)
10:35:38.313: Information: [Thread=1] K4AVideoSource[000209301412]: Initializing for mode NFOV depth + 1280x720 color @ 30Hz
10:35:38.313: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:35:38.314: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:35:38.314: Information: [Thread=1] K4AVideoSource[000209301412]: Refreshing status
10:35:38.314: Information: [Thread=1] K4AVideoSource[000209301412]: Initialized mode NFOV depth + 1280x720 color @ 30Hz
10:35:38.314: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming starting...
10:35:38.314: Information: [Thread=1] K4AVideoSource[000209301412]: Starting cameras...
10:35:38.599: Information: [Thread=1] K4AVideoSource[000209301412]: Starting background thread...
10:35:38.600: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming started.
10:35:38.600: Information: [Thread=7] K4AVideoSource[000209301412]: Started background thread.
10:35:38.600: Information: [Thread=1] iPiRecorder.Recorder.Bundles.SourceBundleInfo: Rendering FPS limit set to 20
10:35:38.716: Information: [Thread=1] iPiRecorder.Recorder.ViewModel.CameraSettingsManager: Applying camera settings from registry for [Azure Kinect K4A:000209301412]
10:35:38.976: Information: [Thread=1] iPiRecorder.Recorder.ViewModel.CameraSettingsManager: Camera settings applied.
10:38:08.767: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:38:08.767: Information: [Thread=1] K4AVideoSource[000209301412]: Set stop event and join capture thread.
10:38:08.767: Information: [Thread=7] K4AVideoSource[000209301412]: Stopped background thread.
10:38:09.329: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:38:09.540: Information: [Thread=1] #=z9xwQ2Y$ovMzdKL_DvKFTJClRWHGW: Created GPU camera rendering pipeline for Azure Kinect: depth: 640x576 (Depth)
10:38:09.602: Information: [Thread=1] K4AVideoSource[000209301412]: Initializing for mode NFOV depth @ 30Hz
10:38:09.602: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:38:09.602: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:38:09.603: Information: [Thread=1] K4AVideoSource[000209301412]: Refreshing status
10:38:09.603: Information: [Thread=1] K4AVideoSource[000209301412]: Initialized mode NFOV depth @ 30Hz
10:38:09.603: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming starting...
10:38:09.603: Information: [Thread=1] K4AVideoSource[000209301412]: Starting cameras...
10:38:09.923: Information: [Thread=1] K4AVideoSource[000209301412]: Starting background thread...
10:38:09.924: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming started.
10:38:09.924: Information: [Thread=1] iPiRecorder.Recorder.Bundles.SourceBundleInfo: Rendering FPS limit set to 30
10:38:09.925: Information: [Thread=20] K4AVideoSource[000209301412]: Started background thread.
10:38:17.421: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:38:17.421: Information: [Thread=1] K4AVideoSource[000209301412]: Set stop event and join capture thread.
10:38:17.421: Information: [Thread=20] K4AVideoSource[000209301412]: Stopped background thread.
10:38:18.344: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:38:18.506: Information: [Thread=1] #=z9xwQ2Y$ovMzdKL_DvKFTJClRWHGW: Created GPU camera rendering pipeline for Azure Kinect: depth: 512x512 (Depth)
10:38:18.645: Information: [Thread=1] #=z9xwQ2Y$ovMzdKL_DvKFTJClRWHGW: Created GPU camera rendering pipeline for Azure Kinect: color: 2048x1536 (Jpeg)
10:38:18.645: Information: [Thread=1] K4AVideoSource[000209301412]: Initializing for mode WFOV depth + 2048x1536 color @ 30Hz
10:38:18.645: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:38:18.645: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:38:18.645: Information: [Thread=1] K4AVideoSource[000209301412]: Refreshing status
10:38:18.646: Information: [Thread=1] K4AVideoSource[000209301412]: Initialized mode WFOV depth + 2048x1536 color @ 30Hz
10:38:18.646: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming starting...
10:38:18.646: Information: [Thread=1] K4AVideoSource[000209301412]: Starting cameras...
10:38:18.894: Information: [Thread=1] K4AVideoSource[000209301412]: Starting background thread...
10:38:18.895: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming started.
10:38:18.895: Information: [Thread=1] iPiRecorder.Recorder.Bundles.SourceBundleInfo: Rendering FPS limit set to 20
10:38:18.895: Information: [Thread=29] K4AVideoSource[000209301412]: Started background thread.
10:38:32.379: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:38:32.379: Information: [Thread=1] K4AVideoSource[000209301412]: Set stop event and join capture thread.
10:38:32.379: Information: [Thread=29] K4AVideoSource[000209301412]: Stopped background thread.
10:38:33.311: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:38:33.475: Information: [Thread=1] #=z9xwQ2Y$ovMzdKL_DvKFTJClRWHGW: Created GPU camera rendering pipeline for Azure Kinect: depth: 512x512 (Depth)
10:38:33.543: Information: [Thread=1] K4AVideoSource[000209301412]: Initializing for mode WFOV depth @ 30Hz
10:38:33.543: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopping...
10:38:33.543: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming stopped.
10:38:33.543: Information: [Thread=1] K4AVideoSource[000209301412]: Refreshing status
10:38:33.544: Information: [Thread=1] K4AVideoSource[000209301412]: Initialized mode WFOV depth @ 30Hz
10:38:33.544: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming starting...
10:38:33.544: Information: [Thread=1] K4AVideoSource[000209301412]: Starting cameras...
10:38:33.806: Information: [Thread=1] K4AVideoSource[000209301412]: Starting background thread...
10:38:33.807: Information: [Thread=1] K4AVideoSource[000209301412]: Streaming started.
10:38:33.807: Information: [Thread=20] K4AVideoSource[000209301412]: Started background thread.
10:38:33.808: Information: [Thread=1] iPiRecorder.Recorder.Bundles.SourceBundleInfo: Rendering FPS limit set to 30
PostPosted: Wed Jun 10, 2020 4:31 am
Thanks for the info
Please let me know your hardware config (CPU, GPU, RAM).
Do you have a cable connected to the sync port on Kinect camera? If yes, try without it.
PostPosted: Wed Jun 10, 2020 4:51 am
I've just checked your screenshot from Azure Kinect Viewer and noticed that it indicates both In and Out sync connectors are in use. So that is the most likely cause of the issue. iPi Recorder automatically puts a camera in Master or Slave mode if it detects sync connection.
To use synchronization correctly, plug a sync cable to OUT of one camera (which becomes a master) and IN of another (which becomes a slave). Then both cameras will produce synchronized pictures as expected. When shooting with a single camera, don't plug a sync cable to it, at least not in the IN port.
PostPosted: Fri Jun 12, 2020 1:49 am
Thank you a lot!
It worked.
Please add an option to set the camera a master or a slave.
Best regards,
Matvey Safroshkin
Users browsing this forum: No registered users and 134 guests
