It is currently Sun Nov 08, 2026 6:07 pm
PostPosted: Thu Jan 07, 2021 2:56 pm
Hello!
We'd like to use iPiSoft while simultaneously recording with Depthkit, a depth sensor-based volumetric capture solution. Ideally, we'd be able to record with both solutions at the same time on two different computers and ensure that the Azure Kinects do not interfere and while remaining globally synchronized. If we simply add the Azure Kinects in use by your tool in series at the end of the sync chain would that work? The first Azure Kinect in use by the recorder would have both an audio cable in the in and out ports and the second one would have only a cable in.
PostPosted: Fri Jan 08, 2021 12:30 am
This should be possible. You just need to ensure that a master camera (the first in a chain) is started before (or simultaneously with) the ones used in iPi Recorder. Otherwise Recorder detects that there is no sync signal from a master and puts a subordinate camera in the error state. In Recorder, cameras are started when you press "Record Video" button on the home screen.
