It is currently Mon Nov 09, 2026 1:53 am
 Post subject: Delete Tracked Frames?
PostPosted: Sun Feb 07, 2010 12:08 am
1.) In my experience in tracking in DMC, there is always an arm or both that is not tracked successfully resulting the arm poke through the head or body even if I do a Hi-Res Tracking.
Because of this I locate the frame which the incorrect track started and manually correct them using IKs and Rotate and do the same at the rest of the mistracked frames.
Its a time consuming process but its alright with me. I think its a necessary work due to the software's limitations.
But it becomes a little difficult to do for after finishing manually correcting one frame, the next unedited frame turns to its originally tracked pose. If I can delete a set of frames which every unedited frame copies the last pose that was edited and will not affect the correctly tracked frames, it will going to be much easier.
PostPosted: Mon Feb 22, 2010 4:27 am
Hi Owl
I would like to add my vote for this as well
cheers
Steve Skinner
Users browsing this forum: No registered users and 65 guests
