It is currently Sun Nov 08, 2026 3:19 pm
PostPosted: Wed Apr 27, 2022 6:14 am
hey everyone, I have a dual kinectV2 system and I want to record people's simple straight walk and 1 turnaround for biomedical purposes. so u see the gestures aren't too complicated but I need fairly good accuracy. now I was wondering what is the maximum capturing area with dual Kinect system? and with which camera setup will I achieve that (180/90)?
my room is rather large 8*6 meters so I don't have problems.
I really appreciate it if you could help me. thanks
PostPosted: Thu Apr 28, 2022 1:19 pm
The capture area for Kinect v2 is typically about 2.5x2.5 meters. As the distance between a camera and a person should be in the range from 2.5-3 m to 5-6 m. Closer, a person may not fit full-height. Further, the quality of depth data degrades substantially.
As you mention the full turnaround motion, I'd recommend a 180 degrees setup. You can get the max distance of ~3.5-4 m if a person walks by the diagonal between two cameras, not straightly from one to another.
PostPosted: Thu Apr 28, 2022 10:49 pm
thank you so much, i really need 3.5 meters walkway, it would be awesome.
and i was wondering in the 180 setup the distance between cameras should be 6m?
PostPosted: Fri Apr 29, 2022 6:53 am
The ideal distance to maximize the capture area is 7-8 m.
PostPosted: Fri Apr 29, 2022 10:45 am
thank you so much
Users browsing this forum: No registered users and 76 guests
