It is currently Sun Nov 08, 2026 4:50 pm
PostPosted: Sun Apr 14, 2019 7:36 am
Hello. For some reason I can not test this program. I downloaded the program, but it shows that my trial period has expired. But I have not previously used this program.
I tried reinstalling Windows but it also did not help. I again get the message that my trial period is over.
I want to test this program, as I plan to buy it if it will meet my requirements.
What could be the problem? My OS - Windows 10
Thank you,
Nikolai.
PostPosted: Sun Apr 14, 2019 9:17 am
Trial can expire right after activation, if there is substantial difference between computer clock time and server time.
Trial is locked to hardware configuration so reinstallation of OS doesn't help.
However, you can still use expired trial for evaluation. Only animation export is locked, but you can transfer motions to other characters and preview in iPi Mocap Studio.
PostPosted: Sun Apr 14, 2019 9:37 am
vmaslov
Thank you for answer.
The problem is that I want to test this skeleton in 3ds max and Modo.
I necessarily need to test several times completely work with this program before buying.
Is it possible to change the time of the computer clock to match the server time?
Or any other solution?
PostPosted: Sun Apr 14, 2019 10:54 am
PostPosted: Sun Apr 14, 2019 11:20 am
If you really need to test export you can activate trial on another PC.
Note that you won't be able to export from .ipilocked projects even with non-expired license. So you need to do the full workflow on a PC with non-expired trial - from project creation to export.
PostPosted: Fri May 13, 2022 7:07 am
So, there is an absurd attempt to prevent the trial version from prevailing. That explains the high consumption of the program that swallows 80% of 2 cores. They have practically integrated a DRM that slows down the program, and another of the flaws is that if you mistakenly go forward several days in Windows and try to reset the time and day, the program has already consumed those days in advance. So if you move your Windows clock forward 29 days and go back to your time, just one day passes and time runs out.
Users browsing this forum: Baidu [Spider] and 163 guests
