It is currently Sun Nov 08, 2026 4:50 pm
 Post subject: Trembling interface
PostPosted: Wed May 19, 2010 3:14 am
Hello, i have just updated the ipisoft and the interface is trembling....it seems a bug and how can i fix it, i have to work with it tomorrow.
And when i open a 4 cams videos, and then i try to import a personal rig, there is a software crash.
www.apside3d.fr
 Post subject: Re: Trembling interface
PostPosted: Wed May 19, 2010 12:05 pm
This can be a bug. We are working to reproduce and fix it.
Your description is not quite clear. Can you please describe in more detail, what kind of trembling to you see?
What video card do you use? What version of Windows to you use (XP, Vista, Win7)?
What is the exact version of iPi Studio on your computer? Is it 1.0.0.95 or 1.0.0.96 or 1.0.0.97?
We fixed a similar bug with crash on target character import, maybe you just need to upgrade to latest version (1.0.0.97).
You can wait for the fix; alternatively, you can roll back older version. To do this, go to "Uninstall Programs" in Control Panel, select iPi Studio and press "Uninstall/change" button, then select "Restore the application to its previous state".
http://www.ipisoft.com/images/restore_p ... rsion1.png
http://www.ipisoft.com/images/restore_p ... rsion2.png
PostPosted: Thu May 20, 2010 2:48 am
when i open ipisoft dmc the viewport is trembling, just a little staedy shake. It desappear when i enlarge the interface just a little. It's a minor bug...
the dmc version is 1.0.0.97
my video card is 8800gt on windows XP;
thanks for your answer !
www.apside3d.fr
PostPosted: Thu May 20, 2010 12:46 pm
We published a new version that should fix the problem with UI. However, the bug is somewhat random and is not easy to reproduce. Can you please run latest version and let us know if the problem with UI is fixed.
We cannot reproduce this bug in our testing. Can you please send me the rig that causes crash, so that we could debug the problem?
PostPosted: Sun Jun 06, 2010 3:54 am
I get the trembling viewport as well, but if you maximise the window it stops. Maybe it's a scaling issue? I went from .90 to .98 and started getting it then.
WinXP SP2
GeForce GTX285, driver version 6.14.11.9713
Users browsing this forum: Baidu [Spider] and 162 guests
