It is currently Sat Aug 15, 2026 11:11 am
PostPosted: Mon Jan 24, 2011 10:51 pm
I bought 4 Sony eye cameras in December 2010 (about a month ago). I finally opened one up and decided to do a bandwidth test with the ipiRecorder on my system. I read somewhere on the forums about a new revision of Sony eye cameras that require a new driver, but I'm not even sure that any driver at all was installed with ipiRecorder. What do I need to do to get this working?
PostPosted: Mon Jan 24, 2011 11:15 pm
Did you have an earlier version of iPi Studio installed? If so, try uninstalling it before installing the latest build. The downloaded version of the software (as opposed to auto-update) will install the latest drivers if they don't already exist on your computer.
Hope this helps.
PostPosted: Tue Jan 25, 2011 8:28 am
No, this is the first thing I've ever installed related to iPiSoft or Sony eye cams.
PostPosted: Tue Jan 25, 2011 12:48 pm
Hmm. That's strange. It really should be .plug-and-play', which has been the case with the laptop and two different desktops I've used Recorder with.
Which operating system are you running? I've only run iPi Studio with Vista Pro and Win 7 Pro on desktops. I think there may have been some issues with XP in the past, but I don't know if that's still true. I did run Recorder on my old laptop running XP Pro a couple of years ago and it seemed to work then, so I don't know.
Hopefully one of the iPi guys will pop in soon to help.
PostPosted: Tue Jan 25, 2011 6:07 pm
I'm running Vista Home 64-bit on this particular PC. I haven't tried it on any others yet.
PostPosted: Wed Jan 26, 2011 12:39 pm
Do you see "iPi WinUSB Driver Registration for Sony PS3 Eye Camera x64" when you go to "Control Panel\Programs\Programs and Features"?
What happens when you connect camera and start iPiRecorder?
Please try connecting camera to different USB port and/or rebooting the system. There is a chance this is a hardware problem.
PostPosted: Wed Jan 26, 2011 1:05 pm
Nope, the only thing I see related to that is iPi Recorder. There is nothing about drivers installed. Like I said, the installer doesn't appear to install any drivers.
PostPosted: Wed Jan 26, 2011 3:12 pm
Please try installing the following driver from our website:
http://www.ipisoft.com/downloads/driver ... Pi-x64.msi
The one above is 64-bit. For other user possibly having similar problem, here is the 32-bit version:
http://www.ipisoft.com/downloads/driver ... Pi-x86.msi
PostPosted: Thu Jan 27, 2011 1:52 am
The 64-bit drivers worked (after multiple restarts). You'll probably want to include the drivers with the iPiRecorder download.
PostPosted: Thu Jan 27, 2011 10:03 am
Normally, the drivers do get installed with the installer. Not sure why that didn't happen with your system, but I'm glad you got it working. :)
Users browsing this forum: No registered users and 69 guests
